spark plug change
yes you can. remove each of the spark plug boot/coil assemblies, and pull the plugs one by one, then reinstall the boot/coil one at a time starting with the furthest one from you, working your way back to cyl number one closest to clutch.
the boots are super tight, twist them clockwise and counter clockwise till they loosen to the top. (do not pry on them with anything). before reinstalling them, add a dab or dialectric grease to the inside of the boot. ski
