- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Got my Snow Week magazine today and it has the official results from the shoot out on December 10th in Woodgate, NY.
Stock Weights
Yamaha RS Vector.....615 lbs
Skidoo MXZ 600 HO (included electric start).....560 lbs
Polaris 600 XC SP.....541 lbs
Arctic Cat F6.....524 lbs
Yamaha RX-1.....630 lbs
Ski Doo Mach Z (included electric start).....625 lbs
Polaris 900 Fusion.....599 lbs
Arctic Cat ZR 900.....560 lbs
All machines were weighed with 5 gallons of fuel, oil reservoirs full, equipped with trail carbides, and studded equally.
Stock Weights
- Apr 17, 2003
- Menno, SD
- Menno, SD
Stock 600 Class Box Stock Best Recorded Run
Yamaha RS Vector:
60 ft: 1.793
330 ft: 5.077
660 ft: 8.111
1000 ft: 10.951 & 85.23 mph
1/4 mile: 13.514 & 85.87 mph
Ski Doo MXZ 600 HO:
60 ft: 1.637*
330 ft: 4.946*
660 ft: 7.962
1000 ft: 10.839 & 80.93 mph
1/4 mile: 13.429 & 84.26 mph
Polaris 600 XC SP:
60 ft: 1.735
330 ft: 5.054
660 ft: 8.118
1000 ft: 10.937 & 83.80 mph
1/4 mile: 13.467 & 86.37 mph
Arctic Cat F6:
60 ft: 1.822
330 ft: 4.967
660 ft: 7.798*
1000 ft: 10.436* & 91.46* mph
1/4 mile: 12.802* & 93.16* mph
* means fastest ET or speed for the class
Yamaha RS Vector:
60 ft: 1.793
330 ft: 5.077
660 ft: 8.111
Ski Doo MXZ 600 HO:
60 ft: 1.637*
330 ft: 4.946*
660 ft: 7.962
Polaris 600 XC SP:
60 ft: 1.735
330 ft: 5.054
660 ft: 8.118
Arctic Cat F6:
60 ft: 1.822
330 ft: 4.967
660 ft: 7.798*
- Apr 17, 2003
- Menno, SD
- Menno, SD
Stock 600 Class Dealer Prep Best Recorded Run
Yamaha RS Vector:
60 ft: 1.802
330 ft: 5.082
660 ft: 8.141
1000 ft: 10.973 & 84.91 mph
1/4 mile: 13.520 & 86.37 mph
Ski Doo MXZ 600 HO:
60 ft: 1.658
330 ft: 5.047
660 ft: 8.224
1000 ft: 11.282 & 78.12 mph
1/4 mile: 14.046 & 79.64 mph
Polaris 600 XC SP:
60 ft: 1.582*
330 ft: 4.785*
660 ft: 7.729*
1000 ft: 10.530* & 85.23 mph
1/4 mile: 13.054 & 85.71 mph
Arctic Cat F6:
60 ft: 1.679
330 ft: 4.916
660 ft: 7.867
1000 ft: 10.609 & 88.24* mph
1/4 mile: 13.051* & 90.36* mph
Yamaha RS Vector:
60 ft: 1.802
330 ft: 5.082
660 ft: 8.141
Ski Doo MXZ 600 HO:
60 ft: 1.658
330 ft: 5.047
660 ft: 8.224
Polaris 600 XC SP:
60 ft: 1.582*
330 ft: 4.785*
660 ft: 7.729*
Arctic Cat F6:
60 ft: 1.679
330 ft: 4.916
660 ft: 7.867
- Apr 17, 2003
- Menno, SD
- Menno, SD
Open Stock Class Box Stock Best Recorded Run
Yamaha RX-1:
60 ft: 1.750
330 ft: 4.810
660 ft: 7.605
1000 ft: 10.216 & 92.98 mph
1/4 mile: 12.555 & 93.74 mph
Ski Doo Mach Z:
60 ft: 1.773
330 ft: 4.832
660 ft: 7.519
1000 ft: 10.009 & 97.19* mph
1/4 mile: 12.251 & 98.25* mph
Polaris Fusion 900:
60 ft: 1.522*
330 ft: 4.639*
660 ft: 7.482
1000 ft: 10.102 & 91.84 mph
1/4 mile: 12.466 & 92.02 mph
Arctic Cat ZR 900:
60 ft: 1.699
330 ft: 4.710
660 ft: 7.367*
1000 ft: 9.850* & 97.19* mph
1/4 mile: 12.086* & 98.25* mph
Yamaha RX-1:
60 ft: 1.750
330 ft: 4.810
660 ft: 7.605
Ski Doo Mach Z:
60 ft: 1.773
330 ft: 4.832
660 ft: 7.519
Polaris Fusion 900:
60 ft: 1.522*
330 ft: 4.639*
660 ft: 7.482
Arctic Cat ZR 900:
60 ft: 1.699
330 ft: 4.710
660 ft: 7.367*
- Apr 17, 2003
- Menno, SD
- Menno, SD
Open Stock Class Dealer Prep Best Recorded Run
Yamaha RX-1:
60 ft: 1.711
330 ft: 4.819
660 ft: 7.661
1000 ft: 10.311 & 91.09 mph
1/4 mile: 12.678 & 92.78 mph
Ski Doo Mach Z:
60 ft: 1.823
330 ft: 4.859
660 ft: 7.508*
1000 ft: 9.935* & 101.81* mph
1/4 mile: 12.12* & 101.34* mph
Polaris Fusion 900:
60 ft: 1.621*
330 ft: 4.793
660 ft: 7.741
1000 ft: 10.468 & 88.41 mph
1/4 mile: 12.920 & 88.58 mph
Arctic Cat ZR 900:
60 ft: 1.692
330 ft: 4.769*
660 ft: 7.534
1000 ft: 10.086 & 94.74 mph
1/4 mile: 12.374 & 96.35 mph
Yamaha RX-1:
60 ft: 1.711
330 ft: 4.819
660 ft: 7.661
Ski Doo Mach Z:
60 ft: 1.823
330 ft: 4.859
660 ft: 7.508*
Polaris Fusion 900:
60 ft: 1.621*
330 ft: 4.793
660 ft: 7.741
Arctic Cat ZR 900:
60 ft: 1.692
330 ft: 4.769*
660 ft: 7.534
grader
nice to see a dealer slow the rx1 down again.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
If the RX-1 is nick named the RX1ton by the bashers, what should we call the MachZ that is a measley 5 pounds lighter :ORC
It's pretty easy to get lighter with the RX-1 too. Swap out the seat or Exaust alone and either one will drop over 10 pounds.
welterracer
DID ANYONE NOTICE BESIDES ME THAT 95% of the sleds that were DEALER PREPED went SLOWER??
12.55 isnt that great either for the Rx... 12.2 would be alot better and fesiable if they got the 60 foot time a little lower..
The only sleds that actually benifited from the clutching was the MACH Z and the XC 600.. not bad for a 600..
GOD I WISH I HAD SOME SNOW AND A 1/4 TRACK AROUND HERE WHERE I COULD FIND OUT HOW MY WARRIOR WOULD DO IN THE 1/4 MILE!!
SRXSPEC.... They must have installed there SLOW DOWN KITS AGAIN...LOL
Brian..
Brian..
JDKRXW
Looks to me like the ZR9 is going to give the Mach all it can handle. Out of the box it crushed the Mach.
DELTABOX
Yamaha is right there
I just got my snow week today also. Wow considering this is strictly an acceleration test I think the new Yamaha's showed great! If you consider full wet weights the Fusion with a 11.8 gallon tank would increase by about 12 pounds vs the 10 gallon RX-1 making it only 19 lbs lighter than the RX-1 and that is without E-start. The Mach Z will weigh at least 7lbs more full wet. Plus the Mach has less suspension travel than the RX-1.
When compared full wet and with electric start the new Yamaha's are right there weight wise especially considering the competition is 2-stroke twins. In acceleration the Vector is close to the 600s (and the Polaris and Arctic cat posted much higher HP readings than they had previously at Dynotech the magazine even mentioned they thought they might be cheating. The RX-1 acceleration is right there posting competitive ETs and faster mph readings than some open class sleds. And the RX-1 was really marketed and priced to compete against the 800s. To me seeing the perfromance is this close and after riding the new monoshock I'd say it would be hard not to buy a new RX and this comparison doesn't even count in the fact that is is a 4-stroke and all of those benefits....
wavey
Any foot note on wether the Mach Z was running its time after the 4 hour "chip' thing. I got buddies I ride with new Machs and I am just thrilled that they cannot call me mister one ton. 05 RX1
I can't help but think my little ECP/HH kitted 05 RX1 is gonna be right in the mix with alot of unsuspecting stockers in the class.
- Apr 17, 2003
- Menno, SD
- Menno, SD
The reason for the slow downs in dealer prep runs were track conditions. The first runs were done on hard ground with a dusting of snow, but as the day went on the ground turned to a sloppy muddy mess. They make mention of this in the article and were surprised that the XC 600 and Mach Z made gains in dealer prep. In dealer prep the Mach Z was reclutched slightly and the XC was reclutched and the air box was gutted.
The Mach Z had the break in chip still in it as it hadn't been run the 4 hrs required to remove it I believe.
Otis RX
The MACH Z "will" wake up.
My good friend has a MACH Z and you can see it every time we go out on the lake.
The first time out it ran like it had an anchor attached. Couldn't believe how slow it felt. Tach at 8300 (too high). Having had many a Ski-Doo, I knew the chip needed to be burnt in and the rpm were too high. At about 75 miles we changed the TRA primary from the factory setting number 6 working our way up to #1 (7600rpm). The sled got faster as we changed the settings and dropped the rpm's The sled "flys" on the snow. Lake with 1-2 inches of fresh snow had the MACH at 116 radar with his T-Cat at 112. MACH chip still not burnt in!!
Now we know the T-CAT will post 122 (radar) on 1/2 mile ice track.
The MACH is strong, smooth, and will only get faster.
The track in here in OTIS is ready and fast!!!
The MACH won't be back in town until next week so I'll report back on how it runs the 1/2 mile.
FYI..... my 03 RX-1 ran 117MPH on radar today on the 1/2 mile track.
The MACH will be faster....much faster!!
DELTABOX
Based on the HP the Mach Z dynoed at I'm sure the ski-doo guys switched the chip.
One other point however is that Yamaha was not allowed to supply 4-strokes with broken in motors. The RX and Vector will be even more competitive after broken in....
- 22K
- 7K
- 10K
