Digital LED Temp Gauge
Grimm
Ottawa, Ontario
Canada
2018 MXZ 850
After encountering an overheat situation at the end of the season, I decided to install a temp gauge on my Nytro to monitor coolant temps. After doing a little searching on the internet, I came across a decent deal on a digital gauge, rad hose adapter and gauge pod.
I wanted something a little different and opted to try an LED gauge, looks pretty cool, I think. What do you guys think?
ya looks pretty good. Who did you get it from? iam looking for something like that to.
Otter
Here's the mount cup I used:
http://prosportgauges.com/52mm-2-1-16-mounting-cup.aspx
I also saved 10% in shipping with a coupon code that I searched around on the internet for. I can't remember the code. It was something like cracked or crushed.
Regarding the hose adapter, the smallest they have is 28mm, which is a little bigger than the 1 inch hose on the Yammys, however I still managed to make it fit, nice and tight.
Here's a couple of more pics of where I mounted it. I have relocated my speedo with a Phazer bracket you can still see the temp gauge behind it.
Digital gauge.
I still have an extra daytona digital gauge with thew hose adaptor $95.00 plus sh
Where were you installing the hose adaptor? In the hose behind the rad, or down on the right side along the oil tank? For those who installed them in either location, what was the difference in temp readings? Also, Yamy uses 1" hoses correct? Thanks.
That looks awesome and it also looks like its easy to read as well. I was looking at the Ulmer kit, but I think I like the looks ofthat one better. And its cheaper too.
