yamashaker
- Nov 12, 2010
- Candle Lake, SK.
- 2007 Attak GT / 2017 Sidewinder LTX
Can someone post Turk's clutching for a Nytro RTX with drag n fly weights. I have full Excell header's and exhaust that makes big power and engine needs to run at 9000 rpm.
shadow44
1 bolt 3 washers in arm
1 bolt in od
1 bolt 1 washer in tip
centre empty
run black hc spring
1 bolt in od
centre empty
run black hc spring
yamashaker
- Nov 12, 2010
- Candle Lake, SK.
Does this set-up slam to 9000 and stay there or hit 8800 and pull to 9000? What belt are you using, are you using stock secondary setting? what body weight are you using?
I find it odd no weight in the centre, is that because it pulls too hard in the middle with weight?
shadow44
I believe it hit 9000...drops down a tic ( 8800ish) and climbes back to max...roughly 8950-9050. I run the stock Yammi belt...stock secondary..no changes at all.
yamashaker
- Nov 12, 2010
- Candle Lake, SK.
Thanks a bunch I'll give it a try.
- 6K
