MA03RX1ER
- Feb 12, 2007
- Georgetown, MA
- 2014 SR Viper XTX and 2003 RX1 w/MTN Conversion
I've got an 03 that is converted to a mountain. Mountain skid, mountain brackets, the whole nine. Rode it a couple years and had the hyfax replaced as it was wearing bad toward the front. Did some maintenance recently and noticed the front of the skid is extremely tight to the track. I have the front shock backed off all the way and the limiter straps sucked up 100 percent. Any suggestions on how to get more pressure off the front of the skid?
GUKROKIT
Did you relocate the front arm mount in the tunnel? The shorty uses a different hole for the front arm.
MA03RX1ER
- Feb 12, 2007
- Georgetown, MA
Both holes are actually present in the tunnel. The front mount on a shorty mounts at the front of the footwell where the mountain sits about 3"behind the end of the footwell. I'm thinking it's an issue with the skid itself as when I first put it together I had plenty of slack in the track and I ran it loose. Now it's tight as can be.
