how do you prime oil pump?
ny01srx
Rochester NY
13 nytro
just rebuilt motor looking for info on priming motor or oil pump
oil priming
remove smallest hose fromtank
plug rubber hose and blow a little air
into tank untill you hear it bubbling
do this 2 x then install rubber hose
start and look in tank through fill hole
make sure oil is swirling around in tank
ive rebuilt mine 2x and no oil problems
after doing this
their is another post on this
thank you very much i could not find that info anywhere and that could be a huge mistake not priming that pump......
thanks ,
Jason
