TY 4 Stroke - Totallyamaha Forum Index
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
MemberlistPosting Rules  MemberlistTY Chat SearchYamaha Parts FinderMemberlistOn-Line Store MemberlistVIP
Log in to check your private messagesActive Topic (24h)  (12h)  Log in to check your private messagesMapMemberlistTY.NET Classifieds Log in to check your private messagesTY Webmail
 MemberlistTY Tech
MemberlistTY Home
MemberlistTY Forum
MemberlistATV Forum
Nytro Ice Drag Setup
Post new topic   Reply to topic    TY 4 Stroke - Totallyamaha Forum Index -> FX Nytro General Talk
View previous topic :: View next topic
Author Message
sledneck22
PostPosted: Wed Jan 27, 2010 3:42 pm    Post subject: Nytro Ice Drag Setup Reply with quote
Can anyone tell me a good suspension setup for drag racing on ice/lake. My buddy has a Nytro setup with many mods and wants my help setting it up for this weekend. Transfer rod all the way out? limiter strap out all the way? Front arms below parellel from the ground? Any advice is much appreciated.
Thanks!
_________________
08 Apex MTX, 22/40, DnF Clutch, Cut Maverick Track to 1.5",TD05H custom rear mount turbo (6psi), custom built intake plenum.
-I am a Mechanical Designer - If anyone has any CAD ideas or work for a snowmobile, I have resources and can draw just about anything up.
Custom turbo build: http://www.ty4stroke.com/viewtopic.php?t=112473
Back to top
View user's profile Send private message Send e-mail
kerry king
PostPosted: Wed Jan 27, 2010 9:15 pm    Post subject: Reply with quote
if you are ice draging you want to strap the hole sled down. front down to two inchs left and same on the back
_________________
kerry king
Back to top
View user's profile Send private message MSN Messenger
yami ryder
PostPosted: Wed Jan 27, 2010 9:34 pm    Post subject: Reply with quote
woody's ice picks and chisels...
_________________
98 srx 700
03 rx1
05 vector
08 nytro rtx, excell pipe, ulmer stage 2
08 nytro rtx wife's
04 polaris 800 pro x 2
Back to top
**sj**
Life Time Member
Life Time Member
PostPosted: Wed Jan 27, 2010 9:39 pm    Post subject: Reply with quote
slammed and picked and or chisseled
_________________
looking for more riding friends!
Back to top
yamahahaha
PostPosted: Wed Jan 27, 2010 9:42 pm    Post subject: Reply with quote
slam it down, if it has floats, putting the frolnt down will b easy
_________________
2008 rtx 40th
144 gold diggers (double 7*, single)
skinz super-q exhaust (hauck husher aswell)
excell header
ulmer racing stage 2 clutch kit
ulmer racing K&N filter kit
silver billet fuel cap and ski handle
powermadd 4" riser block
NGK CR10EK's
Back to top
sledneck22
PostPosted: Thu Jan 28, 2010 9:30 am    Post subject: Reply with quote
Alright we aren't going to chissel it because it is normally a trail sled we are just going to an ice race this weekend because the trails are pretty much shot around here. I know what to do on the front suspension but any information on what the rear should be set to? It is an RTX.
_________________
Back to top
SledFreak
PostPosted: Thu Jan 28, 2010 9:41 am    Post subject: Reply with quote
Well an RTX does not have transfer rods. Make sure the blocks are set for full transfer. Better to get a shaved set from Ulmer racing for more transfer. If you are running on ice and you don't have chisels, then you are wasting your time... If you are on snow, then you will alright with regualr studs. Set the floats to 25lbs. Loosen off the rear front shock so it is ratteling. Set the rear to the softest setting. Now strap the rear down so it only has 3" of travel with a chain or strap of some type. Tighten the limiter to take out the play. You only want the skis to be 2"off the ground. Wheeling the front end is no good... Keep the track on the ground and to keep it from spinning. What do you have for clutching? How far are you racing 660?
Back to top
**sj**
Life Time Member
Life Time Member
PostPosted: Thu Jan 28, 2010 6:35 pm    Post subject: Reply with quote
if you cant do chisels at the least do ice picks
_________________
Back to top
Display posts from previous:
Post new topic   Reply to topic    TY 4 Stroke - Totallyamaha Forum Index -> FX Nytro General Talk All times are GMT - 6 Hours
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You cannot download files in this forum
Powered by phpBB © 2001, 2005 phpBB Group
TY4Stroke brought to you by Totallyamaha.com
This site is not an official site of Yamaha Motor Corp, USA or any other Yamaha entity.
Opinions/comments expressed on this site are not that of Yamaha or any other Yamaha subsidiary or affiliated company.
