subaru2006
- Nov 1, 2008
- Minooka, IL
- 2016 Polaris SBA
I was throwing some ideas around in my head and got into thinking of doing a setback on my sled with the zx2. my thoughts were to set the 144 back to 146 and put the new xc pro camoplast track on. i was thinking i could just pop the rivets out from the mounting plate and move the entire thing back but looking at the tunnel i cant move the rear mounting points back too far without it being below the tunnel or run into the coolers. also iam not sure if i can move this skid back in the first place. so here are my questions.
1. is the skid compatible to set back enough to accomodate a 146" track?
2. will i need an anti stab kit with the zx2?
3. exactly how would i go about setting it back(measurements)?
4. anything you want to add?
subaru2006
subaru2006
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
For a 2" longer track you may be able to get get by adding 10" wheels in the back vs the 8" and it might fit where its located otherwise you will have to mount the skid down about 1.5" and then back your 1" the sled may be a little tippy compared to what your used to.
Good luck!
Good luck!
Ratpack
- Oct 11, 2006
- Frewsburg NY
- 2003 RX1
It's only 1" distance. Do you have enough adjustment on your rear axle?
