Trying out Hygears SE Air Shock upgrade. I will keep you posted on how it ride and is improved over stock.
http://www.hygearsuspension.com/yamsnow_Apex_SE_11.html
marq
- Apr 14, 2003
- Bridgman, MI
- 2006 Apex RTX
Are doing this mod as a general improvement to the sled, or was there a particular issue that you're trying to resolve? Also, did you ever run into problems with bottoming out the mega float?
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
I'm surprised how much rust is under there in one year.
I bet that thing rides awesome though.
marq said:Are doing this mod as a general improvement to the sled, or was there a particular issue that you're trying to resolve? Also, did you ever run into problems with bottoming out the mega float?
I was hoping for a plusher ride with less bottoming. The new Hygear shock has a bottoming stopper and help with the harsh bottoming with lower pressure... I will let you know when I ride it for sure.
kinger said:I'm surprised how much rust is under there in one year. I bet that thing rides awesome though.
I know its crazy how fast that paint comes off the arms in the newer sled
mshabaz
- Aug 16, 2006
How much for the upgrades?? And what else did they do to the mega?.
It still in the testing stages but it would be better to call and talk with Ross or John and they would be able to give you better insight.
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
I contacted hygear last april about mods to my megafloat. At that time they didn't have the kit finished and the price i was quoted for just for just the mega float was 250-325. they were not locked in on pricing at the time because the kit was not complete and the product had not been fully tested. ( i think the price actually came down some) The kit they told me about consists of a revalve, addition of an airchamber volume spacer and a revised bottom out bumper.
It did not seem like a bad deal considering hygears stuff usually does what they claim it should do.
The problem for me was that it took a long time for them to finish up the mega kit and i got impaitent with my sled laying around in pieces and i ended up assembling it and moving it from massachusetts up to maine where i ride it.
I was hoping someone would get thier megafloat done and post up some honest results.
I will be watching this thread. please post up some info once you get the chance to put some hard miles on the shocks.
if this works as claimed i just might pull the shock for a weekend i cant ride and ship it into them.
If it's anything like their Ohlins setup you'll love it. I got rid of my mono because of all the other issues with cracking rails and sliders not lasting and went with a ZX2 and had Hygear revalve that one. It's perfect for how I ride. They do great work.
sx7001
- Jun 28, 2003
- Sidewinder
MrSled said:marq said:Are doing this mod as a general improvement to the sled, or was there a particular issue that you're trying to resolve? Also, did you ever run into problems with bottoming out the mega float?
Ok, so we have to upgrade the factory "upgraded shocks" that cost 1k more than the standard set up. Man, I'm happy I bought the standard model. It rode beautiful last winter and only bottomed with two people on and even then it was minor. The only negative is the R/A set up.
mshabaz
- Aug 16, 2006
I'm interested as well with the Hygear upgrades. Their customer service is outstanding and on my old sled , they revalved and resprung my Olin's electronic. The best single mod ever I made to that sled!!! And if someone can take a great product and make it better then I'm all for it!!! Keep us posted mr sled.
Rich Kay
- Mar 29, 2006
- SE MI. Howell
- Yamaha apex rtx
I have that front end set-up on mine and it made a nice improvment. Much better over the small stutter stuff and guards against bottoming.Running overall lower PSI that helps flatter cornering too.
sx7001 said:MrSled said:marq said:Are doing this mod as a general improvement to the sled, or was there a particular issue that you're trying to resolve? Also, did you ever run into problems with bottoming out the mega float?
I agree, I think the Mega Float for Yamaha is an 06 Apex all over again... they need to figure out how to get the ride right without bottoming... if you ride a standard 11 Apex, you know they have that solved.
RTX
- Mar 31, 2005
- 2014 viper rtx
2006 apex rtx
MrSled.
i know there isn't much show yet but did you happen to get a chance to ride and test out the shock upgrades?
I was having problems with my Ulmer Air kit leaking so I didnt have enough time to really experience the kit. I hope soon.
mshabaz
- Aug 16, 2006
Funny u mention leak. As soon as I installed my new air kit and turned it on....every fitting, and I do mean every fitting that was preassembled at ulmers, was leaking! I could just watch the air bubbles coming thru all the sealant they had used. Which meant I had to cut every hose fitting I just hooked up and take off all the fitting, disassemble, and reseal all fittings they made. What an unfortunate waste of time. It holds air now. I suggested to Allen to maybe QC all his fittings before shipping to customers. He should b able to set up a test rig for his product. It will save his customers a boat load of time and aggravation!!! But so far the kit is holding up and I like the convenience of adjustment as I did w my Olin's
- 18K
