What do I need to do to stud my VL?
back country
Winnipeg, Manitoba
Need some opinions here. I want to stud my VL, not for the fact of great cornering /breaking handling as lets face it she is no speed demon. My main reason is hauling heavy loads at the cabin on the lake. Many time I will chew through the snow and spin on the ice with a heavy load, sometimes having to lighten the load and I always will start by running beside it to get started. Can I add a low number of studs just for this purpose (maybe 44 or so) or will that cause unwanted wear on the track? If I do stud is there anything I need to mod? Thanks for any help.
2007 VL
VL studing
Did mine I think 96 studs , you have to have a guard on the bottom of the muffler for contact trial and error for track tightness
Works great loose a few km hour , only did the center picked a paterren off the woody's site
Re: VL studing
Did you make your own muffler protector?
Venture light studding
Yes made my own muffler skid plate and A arm protectors/flotation plates
Nice, did you consider extending your exhaust and adding a shieled to reduce ice build-up in the tunnel? Or is it a problem for you?
Yes i would like to do it it has been on my list to Do!
Hopfully this summer drop the track check all bearings . I was out last monday and had 20lbs of ice under there ! Will drop by the local sled shop to find a old tunnel to use in the project .
