TY 4 Stroke - Totallyamaha Forum Index
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
MemberlistPosting Rules  MemberlistTY Chat SearchYamaha Parts FinderMemberlistOn-Line Store MemberlistVIP
Log in to check your private messagesActive Topic (24h)  (12h)  Log in to check your private messagesMapMemberlistTY.NET Classifieds Log in to check your private messagesTY Webmail
 MemberlistTY Tech
MemberlistTY Home
MemberlistTY Forum
MemberlistATV Forum
apex track tension with pioneer wheel lowering kit?
Post new topic   Reply to topic    TY 4 Stroke - Totallyamaha Forum Index -> Apex General Talk
View previous topic :: View next topic
Author Message
almond1000
PostPosted: Mon Feb 18, 2013 10:12 pm    Post subject: apex track tension with pioneer wheel lowering kit? Reply with quote
Just put the pioneer spacer kit in which lowers the 6 idler wheels on my 11 apex and in my 11 vector. Did new slides in both sleds as well. Just wondering if anyone is using this kit and what they are running for track tension. Both sleds are the mono shock skids. Apex 128 and vector 121. I sucked the limiter straps up and put wheel kits in hoping to get some life out of the slides. First set lasted 840 miles on apex and 875 miles on vector. Slides were through in the front before the wheels. I run 153 studs in apex and 120 studs in vector. The straps were pulled tighter the day i bought them. The wheel kits added tonight. So just curious where to start with track tension. Thanks everbody
Back to top
View user's profile Send private message
ranger1
PostPosted: Mon Feb 18, 2013 11:03 pm    Post subject: Reply with quote
I have the larger wheels which would probably = the same as your lowering kit, I kept the track tension the same as it was.
Back to top
snowbiscuit
PostPosted: Tue Feb 19, 2013 7:25 am    Post subject: Reply with quote
I have PP kit on SE... set at what Yamaha recommends and forget about replacing slides
Back to top
sgauthier
PostPosted: Tue Feb 19, 2013 9:10 am    Post subject: Reply with quote
i've got the 6 oversize lower idlers on my XTX as well as 2 sets of marginal wheels. Yesterday i was going over my sled before my up coming week trip so i measured my slides and i've only used 1mm in 2000KM. wow what a difference from before these wheels. Only got 1000km before. i set my track to stock tension then backed it off a little. it does have some sag when it's up but not loose enough to hit the exhaust. they should come stock with these wheels.
_________________
2011 Apex XTX
2002 Vmax 700 deluxe
2001 SRX
1998 SRX
Back to top
Display posts from previous:
Post new topic   Reply to topic    TY 4 Stroke - Totallyamaha Forum Index -> Apex General Talk All times are GMT - 6 Hours
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You can download files in this forum
Powered by phpBB © 2001, 2005 phpBB Group
TY4Stroke brought to you by Totallyamaha.com
This site is not an official site of Yamaha Motor Corp, USA or any other Yamaha entity.
Opinions/comments expressed on this site are not that of Yamaha or any other Yamaha subsidiary or affiliated company.
