2008 Nytro RTX
I noticed on the Viper they are 2s and on the Zr 7000s have float 3s,What is the main difference? I am going down the line and seeing what is going to be theb etter sled for me. RTX SE vs ZR 7000. Forget the Zr 8000 RR with a price tag of around 15,000 dollars! No thanks they can keep that!
LJ 452
Float 3's have the Kashima coating, reduces stiction and improves the stutter characteristics. This is the same coating available from The Fox website as an extra.
2008 Nytro RTX
That wouldn't be something to not get the Viper right? Not that big of deal?
Float 3 has the air fill valve for main chamber in a different position.
DeerHuntr
What is the difference between Floats and Float 2's?? Also I thought I read they were now coming with Float 3's
Looks that way. Original floats didnt have a negative spring in side them spring allowed little bit lower ride hieght with with less pressure and helped with the floats being sticky in the first part of the action. I believe Float 2's also have a small bump stop so no metal to metal contact on bottoming.
