xt_gt
my buddy is looking at getting an apex. he found an 06 gt with 1900 miles. what are these things going for. is $5k to much for this sled for its age? i know they hold their value, just don't know what they go for.
he may be looking at it this weekend.
also what do i tell him to look at? i know it isn't driven much so all should be good, but suspension, anything under hood?
-nick
(are all apex fuel inj.?)
-nick
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
Yes all Apex's are injected. That is a good price with that milage. Wont see much under the hood, The main thing on the GT is the electric shock, make sure it works.
SAB1
- Mar 1, 2011
- Tuftonboro NH
- 2017 Sidewinder LTX SE
2010 Vector GT
2006 Apex
Seems like decent price. Probably depends on where you are also. My son just bought '06 Apex with 170 miles on it for $4500. We had seen several of them kicking around ('06-07's) all seemed to be in the $4400-5000 range. Very quick sled.
Snowmobileaddict
If you want a couple of bargaining chips in your back pocket, check the idler wheels to see if they are original from the factory (solid) or the good spoked replacement wheels (spoked). The originals will fall apart in short order and 6 wheels adds up to a pretty good chunk of change.
Get down with a flashlight and get a good look at the rear skid suspension arms especially the front. Because the shock valving and spring on the gts are so poorly calibrated from the factory on the 06's the arms can take a beating and will develop cracks. A beef up and powder coat treatment from half baked coatings costs about $220. a shock revalve from a reputable shop really turns the ohlins ECS on the gt into a trail tamer.
Fire it up and get up to operating temp (wait till the red light on the dash goes off) and cover the rear exhaust ports with some heavy leather gloves. The engine should die within 8-10 seconds. If it doesn't it means that the exhaust donuts are leaking and will require replacement (parts cost 65-90 dollars) depending on who you buy from.
Take a good look at the running board heat exchangers especially where the skid mounts to the tunnel at the rear. Make sure they are not weeping any coolant. They can develop stress cracks in this area.
With the engine running, press the mode button on the dash until the shock icon is visible. You should be able to step the shock compression damping up and down with the blue right hand warmer switch. If the bar graph indicating the shock damping on the left side of the dash doesn't change, that means the cable to the shock has been severed or torn. If the bar graph responds, all is good.
You can use almost all of these items to beat your seller up a bit on his price. It is a fairly realistic number though if the things above all check out.
xt_gt
thanks. soon another newcomer to the yamaha croud. he for sure is getting an apex. will let you guys know what he gets maybe it's a members?
xt_gt
i stated it was a gt, in fact it's an SE model, also found an RTX.
mainly shock packages is all thats diff? besides colors.
theCATman
- Feb 19, 2007
- WI
- Yamaha
xt_gt said:i stated it was a gt, in fact it's an SE model, also found an RTX.
GT= clicker GYTR fronts & Ohlins Electric Mono-Shock adjust rear
SE/ER= pre-load adjust only basic coil over fronts & tunnel adjust Mono-Shock rear
RTX= Fox Float Gen 1 fronts & Pro-Active torsion rear (sucks #*$&@)
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
06 Apex all have the Mono rear suspension, 07 Apex RTX have the CK pro active rear suspension, does not suck #*$&@, it's an AWESOME rear suspension.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
what sled
step up to a 12' get power steering...exup exhaust valve..and a higher seating position...oh and I have one for sale in the classifieds
BIG BLACK WARRIOR
Sounds a little high to me. I sold. 2007 Apex GT 3 years ago for $5,500.
theCATman
- Feb 19, 2007
- WI
- Yamaha
Teamblue4 said:06 Apex all have the Mono rear suspension, 07 Apex RTX have the CK pro active rear suspension, does not suck #*$&@, it's an AWESOME rear suspension.
I stand corrected about '06 RTX rear. Fair enough...
I must ask, either you weigh 90 lbs soaking wet, or you have had a CK revalved, because in stock form they ARE terrible. I had a Nytro & it was too firm on small bumps, yet bottomed as easy as a Mono on big bumps & any amount of air over 2'
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
260lbs fully suited up, all stock shocks, and have close to 11,000 miles on my 07 RTX Love it.
theCATman said:Teamblue4 said:06 Apex all have the Mono rear suspension, 07 Apex RTX have the CK pro active rear suspension, does not suck #*$&@, it's an AWESOME rear suspension.
xt_gt
Re: what sled
i seen your add, it would be nice but his budget is not much more than $6k.
**sj** said:step up to a 12' get power steering...exup exhaust valve..and a higher seating position...oh and I have one for sale in the classifieds
ranger1
Dumped my 07 RTX because the suspension did suck #*$&@ compared to the mono!!! lolTeamblue4 said:06 Apex all have the Mono rear suspension, 07 Apex RTX have the CK pro active rear suspension, does not suck #*$&@, it's an AWESOME rear suspension.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
facts rtx skid (which is the father to the xtx skid) is a capable skid...but since yamaha straight rates their valving...most get hammered...do a search on here for the progressive valving that turns the stiff ride into a capable ride..
