BTbt
- Apr 11, 2005
- Kettleby, Ontario
- 2017 Sidewinder LTX LE
I was checking Woody's stud application for the Viper ltx and they show a two ply track, but Yamaha and Cat both list the Ripsaw II single ply track.Has anyone seen a production 137 track sled yet, as I am planning to buy studs next week.
09nytro
I'm waiting till I get the sled before I get my studs
yamahabuyer
- Mar 4, 2010
- Greenwood, WI
- srviper and apex
- greenwood wi
I've been running into the same problem. Safest bet is up wait until we see a production sled. One guy says this while another says that. I'm pretty sure they will be single ply but my luck Ill buy studs for a single ply they will end up a two ply.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I don't run single ply studs in single ply Doo track. Not even on the turbo sleds. Many on the Doos do not run single ply big heavy stuff and have no problem at all. 2.86" pitch single ply tracks.
The big heads do not roll well inside the track and rob lots of track HP, HP loss is even worse on 2.52" pitch using big single ply studs.
I use double backers though that are less prone to pullouts. I do not use the "large" double backers for single ply tracks either. Just old two ply Megabites and old double backers. Cudney ran a test on large single ply vs old two ply stud and backers and the difference in lbs that it takes to pull thru the large head vs. smaller head two ply was minimal at best, virtually nothing. When Doo came out with the single ply track they tried to corner the market on "special" single ply studs and charge big pricing on them, also warning of pullouts if using the old two ply stuff. Now that time has passed and guys have been running two ply studs in single ply tracks we know better. They were just marketing ploys to get you to purchase the more expensive single ply heavy stuff. My friends and I even stud the outside bands with two ply stuff on a single ply 2.86" pitch tracks. None of us has ever had problems with pullouts.
The guys that studs and spins his track over every surface on earth, is going to have pullout problems using either one, so it really does not matter, the single ply stuff is not going to save him. He will have pullouts no matter what he uses!
DeerHuntr
Good info. Long been a fan of double backers I've never had a problem with pullouts running them
BTbt
- Apr 11, 2005
- Kettleby, Ontario
I was thinking the same thing about using the 2 ply studs, running doubles should be even safer
Blu2U2
Everyone at Hay Days said it will have the single ply track. I went to Woodys but they didn't seem to think it was a big deal that they are giving our wrong info on their web site...
http://www.ty4stroke.com/viewtopic.php? ... s&start=15
KnappAttack said:I don't run single ply studs in single ply Doo track. Not even on the turbo sleds. Many on the Doos do not run single ply big heavy stuff and have no problem at all. 2.86" pitch single ply tracks.
This is very well said. Not sure why but I have not felt the need for studs lately. Maybe better tracks? I am thankful after replacing SRX track 3 times in 6000mi over fear of track failure from pullouts. Of course if you are racing you NEED studs. If not I would seriously consider a Ice Attack or Ice Ripper. They seem to be holding up real well now.
vsmpowered
- Feb 16, 2009
- Rochester , NY
- Nytro xtx Viper ltx se
or new cobra 1.6 pre studed
vsmpowered
- Feb 16, 2009
- Rochester , NY
Yes that Cobra would be a good one. Sure hope I like the Ripsaw 2. If not that would be my choice since I really liked the Freeride 1.5 on Phazer.
vsmpowered
- Feb 16, 2009
- Rochester , NY
after fixing heat exchanger and 300 in studs plus the new cobra looks tougher
09nytro
Thanks for the great infoKnappAttack said:I don't run single ply studs in single ply Doo track. Not even on the turbo sleds. Many on the Doos do not run single ply big heavy stuff and have no problem at all. 2.86" pitch single ply tracks.
skidooslayer687
- Aug 22, 2013
- Almonte, Ont.
- 2014 Yamaha Sr Viper LTX SE
Definately great info! Glad I read this as I was worried about what Im going to do with mine stud wise when I get it
