Firecat_Freak
I can't remember how the routing was, specifically the routing where it comes out of the tunnel and either up over the front arm from the front, or under neath the front arm. Is there a sb for this routing? I took pictures when I dropped the skid but they proved to be insufficient. Thanks again for the help.
heat exchange
Snowmobileaddict
For best results use a buittload of heavy duty zip-ties
Firecat_Freak
heat exchange said:Here is the pdf of the wiring
Great! Thank you very much!
