dremmick
- Mar 17, 2011
- Savage, MN
- 2008 Nytro
Whos running dupont sliders on a non fully clipped track? any issues? My clips also have the holes in them that are supposed to capture snow and rocks ha ha.
TRUE BLUE SINCE 1980
- Apr 11, 2010
- Central PA
- '10 VECTOR LTX
yea, we are finding out that the material around the DuPont insert is overheating and melting away. My riding bud has that problem on his apex . I am on a Vector with all the windows open and clipped. We run the same speeds all day(W/O) I have problems with my Dupont' s. they work as advertised. He cut the windows open with a utility knife. It helped some but that rubber where there is no clip is making heat.
couch
Was going to use the DuPont slider on the phazer mountains but dealer advised that track should be fully clipped otherwise they wouldn't work properly .... the Yamaha sliders for the viper look to have the inserts at a a greater angle so you may get away with every 2nd window clipped.
dremmick
- Mar 17, 2011
- Savage, MN
- 2008 Nytro
thanks guys!
- Apr 11, 2010
- Central PA
- '10 VECTOR LTX
I would think you would be ok on a phaser in the mountain. We are on hard packed at high speeds. The only time we need to be careful is in the morning when the trails are rock hard.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
TRUE BLUE SINCE 1980 said:yea, we are finding out that the material around the DuPont insert is overheating and melting away. My riding bud has that problem on his apex . I am on a Vector with all the windows open and clipped. We run the same speeds all day(W/O) I have problems with my Dupont' s. they work as advertised. He cut the windows open with a utility knife. It helped some but that rubber where there is no clip is making heat.
Is this a typo?
- Apr 11, 2010
- Central PA
- '10 VECTOR LTX
oops it is. , They work great on my Vector.yamahas said:TRUE BLUE SINCE 1980 said:yea, we are finding out that the material around the DuPont insert is overheating and melting away. My riding bud has that problem on his apex . I am on a Vector with all the windows open and clipped. We run the same speeds all day(W/O) I have NO problems with my Dupont' s. they work as advertised. He cut the windows open with a utility knife. It helped some but that rubber where there is no clip is making heat.
Is this a typo?
- Nov 1, 2009
- 2009 Phazer RTX
TRUE BLUE SINCE 1980 said:oops it is. , They work great on my Vector.yamahas said:TRUE BLUE SINCE 1980 said:yea, we are finding out that the material around the DuPont insert is overheating and melting away. My riding bud has that problem on his apex . I am on a Vector with all the windows open and clipped. We run the same speeds all day(W/O) I have NO problems with my Dupont' s. they work as advertised. He cut the windows open with a utility knife. It helped some but that rubber where there is no clip is making heat.
Is this a typo?
I run them on my phazer but with a fully clipped track (151 challenger extrme, easy upgrade and highly recomended when its track changing time) and they work great.. I run with only an anti stab kit and the read and upper wheels.. NO wear last season!
Yogi_12
- Mar 4, 2012
- Stephenville, Newfoundland
- 2011 RsVenture
I have them on my stock 2011 RS Venture and am quite pleased with them. I can't be sure, but I think the track (stock) is clipped every 3rd window.
I also use running board mounted scratchers in icy conditions.
About 1200km on them so far, and no sign of any wear.
nadekeys
- Oct 20, 2009
- Green Bay, WI
- 2017 Sidewinder LTX LE
2009 Apex LTX GT
2008 Nytro MTX Turbo
I'm clipped every third on my apex ltx gt, put on over 2,000 miles last year with little to no wear. I don't buy that the rubber overheats the duponts simply because it's clipped every third, or normal slides would disappear in no time also. The thinking with a track clipped every third is that the snow is retained in the track and cools/lubricates that way.
dremmick
- Mar 17, 2011
- Savage, MN
- 2008 Nytro
So your saying you have no ear on the track where the rubber is? also my track clips have the little holes in them that are supposed to retain snow to help cool hyfax better. Not sure how that might impact the Vespel inserts
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
Dupont sliders
I put them on my 2012 XTX and they work great, much better than stock. My stock wore out around 500 miles and I already have 1000 miles on the duponts with little wear.
Pete
Pete
dremmick my Freeride is a 1.5in track and has the little holes in clips fully clipped. Stock wheels. No wear to speak of on Duponts last season. Great upgrade!
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
I have an Ice Ripper XT track fully clipped. Every third clip is smooth and the rest have the small indents to trap snow & dirt. My Dupont slides are holding up very well.
