TY 4 Stroke - Totallyamaha Forum Index
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
MemberlistPosting Rules  MemberlistTY Chat SearchYamaha Parts FinderMemberlistOn-Line Store MemberlistVIP
Log in to check your private messagesActive Topic (24h)  (12h)  Log in to check your private messagesMapMemberlistTY.NET Classifieds Log in to check your private messagesTY Webmail
 MemberlistTY Tech
MemberlistTY Home
MemberlistTY Forum
MemberlistATV Forum
Grinding sound?
Post new topic   Reply to topic    TY 4 Stroke - Totallyamaha Forum Index -> FX Nytro General Talk
View previous topic :: View next topic
Author Message
08nytro136
PostPosted: Fri Dec 27, 2013 5:18 pm    Post subject: Grinding sound? Reply with quote
Grinding sound coming from I think the clutch side while riding in deep powder at speeds between 60-75, I adjusted the chain not to long ago to tighten it, but I put it back to normal because it wasn't running right and was giving me a whistling sound at higher speeds, the whistling sound is gone but now this sound appeared. Can't figure out what it is Head Bang
_________________
2008 fx nytro 136
1997 enticer 2
2007 kx250f
1991 arctic cat 440 l/c (blown)
Back to top
View user's profile Send private message
poor farmer/logger
PostPosted: Fri Dec 27, 2013 6:11 pm    Post subject: Reply with quote
Did you check your bearings?
Back to top
nate007
Moderator Life
Moderator Life
PostPosted: Fri Dec 27, 2013 9:13 pm    Post subject: Reply with quote
Please add your location to your site profile, thanks.
You said when riding in deep powder, have you checked your track tensionas well? If the track ratchets it will make a heck of grinding sound, and if it's too loose it may make that whirring noise at high speeds as well, simply by the way it's making contact with the drivers. This can be especially likely if you're running stock drivers, and a longer track will ratchet easier than a shorty in deep powder.
Also like poorfarmer/logger said, check your bearings, especially the driveshaft bearing on the chaincase side.
Also pull the chaincase dipstick and look for metal fragments. You will likely see some sparkles in the oil, but shouldn't see anything big enough to make out it's shape, if that makes sense?I'd hesitate to say nothing bigger than a grain of sand or salt or something, but I'd open the chain case up if there's anything big enough to actually see what shape the metal fragment is.
If you do, it's likely that it's a bearing going out and the metal is part of the draveshaft, so check for any oil leaking out of the chaincase from the tunnel side.
_________________
Light travels faster than sound. That's why some people appear bright until you hear them speak.
Back to top
View user's profile Send private message Send e-mail
08nytro136
PostPosted: Sat Dec 28, 2013 10:53 am    Post subject: Reply with quote
Just wondering, I do have oil leaking but I haven't determined where so I'm think it is a bearing, just wondering but how hard is it to replace this bearing? Thanks for all the help
_________________
2008 fx nytro 136
1997 enticer 2
2007 kx250f
Back to top
Display posts from previous:
Post new topic   Reply to topic    TY 4 Stroke - Totallyamaha Forum Index -> FX Nytro General Talk All times are GMT - 6 Hours
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You cannot download files in this forum
Powered by phpBB © 2001, 2005 phpBB Group
TY4Stroke brought to you by Totallyamaha.com
This site is not an official site of Yamaha Motor Corp, USA or any other Yamaha entity.
Opinions/comments expressed on this site are not that of Yamaha or any other Yamaha subsidiary or affiliated company.
