BlgsRX-1mtn
- Apr 16, 2003
- Billings, MT
- '03 RX-1 Mountain LE
Here's my sled stock (12/21/02) to now (10/15/05) the mods are as follows;
BOSS High Rise seat
Camoplast 2.52 pitch 162" x 15" x 2" track
Fabcraft red mtn grab bar
Fly 8" Billet risers using my old pivot from my 2" SPortech ABR
Fly Billet 45 deg bar hooks
Fly Racing Aerotaper Snow X Mountain bars
Holz ice scratcher
Lefty's DTC (left hand throttle)
Modified FRA
Modified all handle bar wiring so connections on bars are located under the tank cowling for a cleaner look and wrapped in red 3/8" wire loom
MPI 162" extension
MPI 3/4" solid riser under the 8" Fly risers
MPI Cr-Moly A-arms
MPI longer throttle cable
MPI Stage 1 SC
MPI transfer enhancement kit
Polished tunnel
PPD X-MT skis (black/red marbelized)
Red annodized painted/polished billet gas cap
Red annodized painted/polished exhaust tips
Red grilles, skid plate, shock covers, hyfax, & low red chrome windshield
Removed anti-swaybar
Removed excess idler wheels
Removed tool box/beverage holder
SLP longer stainless brake line
SLP Red/Silver Handguards
Wahl Bros. Extros
Modified Whiteknuckle QC-1 exhaust (has stock yamaha x pipe welded in) to better suite the SC kit
The FRA mod was just done in June and only has 2 miles of testing on the city streets. Full test will have to wait until next month (Nov 05).
BOSS High Rise seat
Holz ice scratcher
Modified FRA
MPI 162" extension
MPI Cr-Moly A-arms
MPI Stage 1 SC
Polished tunnel
Wahl Bros. Extros
nice looking sled
what have you done with your rear suspension?
the rear shock doesn't look stock!
i haven't seen this mod before.
close up pic wanted!!!
Ohh ,nice sled by the way=)
BlgsRX-1mtn
- Apr 16, 2003
- Billings, MT
Ryen said:what have you done with your rear suspension?
Ryen, it isn't stock. I took the FRA (full rate adjuster) out of the tunnel and cut it and the alluminum shaft to fit between the rails. This gives you a ride similar to the M-10 suspension that Polaris uses. For some close up pictures of it and a quick description of how to do it go the the RX mountain suspension setup topic the the RX/RS mountain section. I have a few pictures of it on page two of that topic.
BlgsRX-1mtn
- Apr 16, 2003
- Billings, MT
Here's an updated picture of the sled taken today after washing her up.
I also updated my list of alterations made to the sled that are in my first post. The exhaust tips are now polished with red anodized paint inside the slots for the allen bolts and on the inside taper around each exhaust outlet.
I also updated my list of alterations made to the sled that are in my first post. The exhaust tips are now polished with red anodized paint inside the slots for the allen bolts and on the inside taper around each exhaust outlet.Attachments
BlgsRX-1mtn
- Apr 16, 2003
- Billings, MT
BlgsRX-1mtn
- Apr 16, 2003
- Billings, MT
I now have Fly bars and 8" pivot riser but, am still waiting on my brake line, throttle cable and grab handle from MPI to arrive. I'll get pictures posted once they arrive.
Jim
Jim
MOTOWN SPEEDFREEK
Thats nice, But i love my Silver/ Orange flames.
BlgsRX-1mtn
- Apr 16, 2003
- Billings, MT
BlgsRX-1mtn
- Apr 16, 2003
- Billings, MT
Well, Santa's helper just dropped off three boxes of crap today. Here's what my hearth for the wood stove looks like at the moment. I'll take pics of the sled once the kit is installed.
Jim
Jim
KbxSrx
now, if you had an ekholm tunnel, with drop and roll, 162" track and an ekholm skid, that thing would be PERFECT!
BlgsRX-1mtn
- Apr 16, 2003
- Billings, MT
KbxSrx said:now, if you had an ekholm tunnel, with drop and roll, 162" track and an ekholm skid, that thing would be PERFECT!
LOL, I have one of the items you listed. I do have a 162" track. The skid and tunnel (w/built in D&R) will probably happen neaxt year. I just can't afford it this season.
I'm also kind of partial to having the stock heat exchangers under my feet. I like not having the running boards full of ice. My wife's Polaris has the exchangers on the edge and they ice up right where I like to place my feet.
Jim.
BlgsRX-1mtn
- Apr 16, 2003
- Billings, MT
The MPI Stage 1 SC is IN!!!!
MAC at MPI didn't want me to run it with the red Holtzman Engineering Carb Springs but I can't find mine and couldn't wait for the ones I ordered today to get here.
Here's the initial report and pics;
Sled was running a little lean (17-18) at 3117" elevation so I slid the choke to about 1/4 on and droped the A/F down to th 12 range. I don't know if this is because of the Red Springs or not. I normally ride at 6500-10,000+ in elevation anyhow.
The fugger sure pulls. As a matter of fact, I had to go back to the garage and tighten up the clamps on the bars some more.
The bars pulled back about 3 inches from the sled trying to leave out from under me ( BOOSTED
). It doesn't have that slight surge like the rear mount turbo I rode.
Note, I don't have the SC oil temp or the RPMs working on the Daytona guage. There is a factory oil tempsensor that causes the idiot lighs to flash on the main instrument cluster (this one requires me to drill and tap the oil resevoir) and, I still have the main tach.
Jim
MAC at MPI didn't want me to run it with the red Holtzman Engineering Carb Springs but I can't find mine and couldn't wait for the ones I ordered today to get here.Here's the initial report and pics;
). It doesn't have that slight surge like the rear mount turbo I rode. Note, I don't have the SC oil temp or the RPMs working on the Daytona guage. There is a factory oil tempsensor that causes the idiot lighs to flash on the main instrument cluster (this one requires me to drill and tap the oil resevoir) and, I still have the main tach.
Jim
- 227K
