thunder lips
- Apr 9, 2004
What size studs are you guys running in the RTX Apex's
SledFreak
- Feb 7, 2005
- Ontario. Canada
96 1.325 woody's megabytesthunder lips said:What size studs are you guys running in the RTX Apex's
riverrat
I SECOND THAT!! 1.325"
vice108
3rd
TotallyApex
- Sep 26, 2005
ok, how many and what pattern u going with?
UPsledder
96 Studboy 1.375 down the middle.
leaddog
Woody's Megabites 1.325" 144 with double and single digger backer patten up the middle staying away from the very center where the shock lives.
APEX GT
APEX GT
vice108
144 1.325" Mack studs down the middle in a 4 - 2 pattern and Bergstrom tripple point carbides on the skis
leaddog
Be careful with the shock. Someone said that their track was rubbing on it. Wouldn't want a stud there.
hey vice do you have a template for that pattern you are going with and if so where did you get it. I want to do the same package but dont have a template yet.
quebectcat
- Jul 27, 2005
i want to go with the woodys 144, my question is does woodys make a template for the double backers in the 15" track or do i go 48 doubles and 48 singles? also with the woodys dual runners the charts are for rx-1 skis are the apex skis the same? and should i go with the 8"? coming from a cat to a yamaha....and still waiting on my gt....thanks in advance
vice108
mack7 said:hey vice do you have a template for that pattern you are going with and if so where did you get it. I want to do the same package but dont have a template yet.
I have the "extreme max" template. I used it as a guideline to help make my own pattern that has more scratch lines.
luckyric2
I used 1.325 Woodys Gold Digger's with the 144 pattern on my Rage for 2005(total 162 studs), two inside every row, and two outside every other row. The sled hooked up very well, and i did not pull through any studs after 2500 UP trail miles.
For 2006 i am going to stud an Attak, but i think i am going to stay inside the track. Woodys says for aggressive trail riding they recommend 198 studs. I am thinking of two doubles in one row and a single and double in the next row, this should total 189. Again i will use 1.325 Woodys Gold diggers.
Any thoughts?
Any thoughts?
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
I don't mean to threadjack, but......
A friend of mine seems to think I can run 192 1.5's on my RTX. What's the worst damage that will happen? Can the sled be modified a little to clear the 1.5's?
1CS
1CS
