Front mount turbo support bracket (CNC billet alum) ''Pics''
SuperTurbo
Amherst, Ohio
17 LTXse Sidewinder
What it is, it supports the turbo from the motor in is fixed position to take some of the stress and movement away during trail riding giving life to the header. AND IT IS FOR A CPR KIT ONLY SO FAR. contact Dave @ 440-336-3044 or email dfimachine@hotmail.com
Let me know when you have one finished. I am very interestede in your product, thanks.
Re: Front mount turbo support bracket ( CNC billet alum )
SuperTurbo said:
Guys I know you need pics,, and as soon as we get the proto type complete I will post them it is 99% complete.
What it is, it supports the turbo from the motor in is fixed position to take all the stress and movement away during trail riding giving life to the header. The only problem is indexing the top part were it mounts to the turbo, not all headers have the same height and off set etc. But were it mounts to the motor is pretty much the same, so we are working on this. AND IT IS FOR A CPR KIT ONLY SO FAR. Cause thats what I have.
So give some input of interest.
Good idea... Noticed on my projects, on the dyno, there is some vibrations
that help crack stainless headers. Heat cycles alone is not the problem.
When you settle on a price let me know. I might be interested in two.
4strokes are better than2 said:
will it fit a vector[/qute]
we will find out after this weekend. We have a Vector but not with a turbo kit, but we will see if it mounts to the motor the same. This was made to help myself but thought it could help others so to say we do this at a full time level we don't just came up with a idea and went with it.
Price will be $ 78.00
the turbo position on the vector is the same, but the engine mount side will probably need to be different. jeff
Jeff would that bracket work with the 28r you sent me on the RX1? That is one good looking bracket, bet that took you sometime/effort. ;)!
