Rear rack mounting
gunner_bear
Grand Haven MI
Does any have a picture of the mounting of the rear yamaha rack on a warrior, i just bought a used rack and have no mounting hardware or instruction for the install. What is used to attach, is it stainless bolts? Thanks Jlepo@sbcglobal.net 8)
see below
The picture helps, i have the mount for the standard rx-1 121", :Better change that. can i get a close up picture of the bottom and top where the bolts go thru the heat exchangers, :pics: thanks
rear rack
Check out post by True Blue (rx1 parts for sale getting 06 attack) pic of rack for mtn machine may help you .I have an 04 rx1 mtn with a 121 rack on it i made brackets which are threaded for the bolts to keep the rack on and the brackets stay on machine, so when i take the rack off for the jack seat i haven't got to worry about getting at the nuts under tunnel ,works well .I can post pics if you would like. ;)! :yam:
