RX1Jim
How many have experience using SLP's hayfax anti wear pads on their tracks? These pads seem to make sense to me, the rubber track does not slide very well over the plastic hyfax. I ordered a set today so I'm going to give them a try. I'm also going to add a set of 8" dia. rear wheels to help further reduce rolling resistance. I'm looking to reduce friction to increase gas mileage. Thanks!!
Skydog
I have them on mine, i guess they are working.
Skydog
Skydog
NY_Nytro
- Dec 24, 2004
- Grand Island, NY
- www.gi-snowmobiler.com
I think it was Snowtech mag that said it is not always great to increase rear wheel size in trail sleds. Something about that they actually change the geometry of the skid and can cause problems when full suspension travel is used (bottoming).
Yama-Crazy
- Jan 10, 2005
- S/E Michigan
- 2014 Yamaha Viper rtx
what size are the very rear wheels stock?
black john
rear wheels
rear wheels are 7 in
i got them and they make a big difference in friction, my sled rolls like never before, also noticed that when it was on the lift at idle the track would creep, it never did that before the pads were on. don't know if it helps with gas milage, but less resistance can't hurt.
rfc
skip
rfc
skip
Skydog
The one thing i dont like is the added weight to the track.
QCRider
- Feb 27, 2004
- Seacoast Region, New Hampshire
- www.myspace.com
It really isn't much weight though. Nothing like studs. a 121" track only needs 32 of them and they are not heavy.
Skydog
Yea when i got the bag in the mail it was alot more weight than i was hoping for.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
My Attak is the 2nd sled I used them on. It's the First mod I recommend to anyone!
Skydog
yea i do feel they are worth the money!
HAPPY NEW YEAR BOYS!!!!!!!!!!!!!!!!!
Yama-Crazy
- Jan 10, 2005
- S/E Michigan
also look at the wieght diffence in a fully clipped track compared to a every 3rd window its like 5 lbs more for fully clipped... this is cheaper easier and maybe even better than fully clipped.
Yama-Crazy
- Jan 10, 2005
- S/E Michigan
Re: rear wheels
I stop at the dealer to see what size stock is and they are 7.12...I've seen a pic of a sled with a 8" wheel to the rear and it looks like the track doesn't even touch the hyfax.. Maybe I'm missing something here? My hyfax doesn't even hardly wear to the rear of the sled and that seems like it wouldn't be a good idea the track not being able to touch the hyfax to reduce load on the wheels and axel mount and wheel bearings rail mount to axel etc...puts all the strain upon impack when jumping or rough riding etc... to certain areas and would eventually cause failure of something from what I can see. Maybe I'm wrong or missing something here any input to clear this up would be helpful...thanks!black john said:rear wheels are 7 in
NY_Nytro
- Dec 24, 2004
- Grand Island, NY
Re: rear wheels
I believe when you install larger rear wheels you need to offset the axle to keep the bottom of the wheels in line with the hifax. You just can't install larger wheels.
Yama-Crazy said:I stop at the dealer to see what size stock is and they are 7.12...I've seen a pic of a sled with a 8" wheel to the rear and it looks like the track doesn't even touch the hyfax.. Maybe I'm missing something here? My hyfax doesn't even hardly wear to the rear of the sled and that seems like it wouldn't be a good idea the track not being able to touch the hyfax to reduce load on the wheels and axel mount and wheel bearings rail mount to axel etc...puts all the strain upon impack when jumping or rough riding etc... to certain areas and would eventually cause failure of something from what I can see. Maybe I'm wrong or missing something here any input to clear this up would be helpful...thanks!black john said:rear wheels are 7 in
Yama-Crazy
- Jan 10, 2005
- S/E Michigan
Re: rear wheels
ok so still trying to figure out why you would want a 8"wheel ..is it just a looks thing?? What am I missing here???NY_Warrior said:Yama-Crazy said:I stop at the dealer to see what size stock is and they are 7.12...I've seen a pic of a sled with a 8" wheel to the rear and it looks like the track doesn't even touch the hyfax.. Maybe I'm missing something here? My hyfax doesn't even hardly wear to the rear of the sled and that seems like it wouldn't be a good idea the track not being able to touch the hyfax to reduce load on the wheels and axel mount and wheel bearings rail mount to axel etc...puts all the strain upon impack when jumping or rough riding etc... to certain areas and would eventually cause failure of something from what I can see. Maybe I'm wrong or missing something here any input to clear this up would be helpful...thanks!black john said:rear wheels are 7 in
