Peak HP vs. rpm
milesu
Anybody know what rpm develops the most hp? Have a new Apex and seems to jump almost to 10G's on the tach and would like to know where all my hp is the strongest.
Wow, sure is alot different with these four strokes...not like my 99 Thundercat!
They dynoed it in one of the snowmobile magazines this last fall - I'll try to find it
Don't forget that your engine will have to broken in before you develop that peak HP
Wow, thanks for the help. I better wait til it has a few hundred more miles on it before I worry about more performace.
rpm
dyno tec has tested several and they have all been there 10.700-10800. a bit higher than the rx 1 i would guess that thats why yamaha put a steeper gear reduction in this moter to run higher rpms with longer dration and higher lift cams so that the clutch rpm,s would run at or below 9000 rpm.
Copy of the peaks off of Dynotech.
hp
i re checked my sheets and they dont look the same as the ones that are posted here. humm. differt air temps and or humity maybe? looks like a totaly differnt moter manufature. even the on the exel exh. if thats it i stand correted. ;)!
Black John, I pulled those directly off of Dynotech yesterday afternoon.
We put my ATTAK on the dyno Maxed out at 10 600 but 0.5 less only at 10 400 and 10 500, and 10 700 but drops rapidly at 10 800... I'm aiming 10 400 to 10 600...
RASH
