Starting point on transfer straps, rods, front shock?
Travis Moore
New York
Just starting to learn the suspension adjustments. I took LB's suggestion and put the rear shock preload to min. and the FRA to max(down). Just looking for a starting point on the straps, front shock and transfer rods. This is for Quebec riding, mostly fast and smooth. What changes should i make for speed runs on a lake? I am attaching a picture of my transfer rods as i think they are aftermarket(i bought the sled used). Thanks much!!
Travis
Pretty sure 2 lines exposed on the transfer rods is stock. More lines exposed will reduce transfer and help keep skis planted. Less lines will increase transfer and holeshot.
15mm from base of nut to tip of threaded adjuster is stock of the limiter strap.
