YAM182
- Dec 19, 2003
March 2,2006.Finally hit the reservoir on Tug hill on a trail ride when conditions were pretty good for opening up the Apex GT with the Ulmer kit installed.
4 sleds ran on softer hardpack conditions.
Line up as follows-
Sled #1.Polaris 900 Fusion 05,studded,rider #220+? Mods?
Sled#2.Yamaha RTX 06,studded,rider #220.Mods-primary weights,
helix,geared up,transfer set toward max.Air box -(sounds like my
old Warrior with filters)something done(or removed) but he won`t say.Low
windshield.NO REVERSE.This RTX has put up 118-121 mph on radar
before.
Sled#3.Yamaha RTX 06,studded,rider #300+.Mods-extra wheels and
bigger dia rear wheels.Big boy spring.Low windshield.Transfer
toward max. NO REVERSE.This RTX has put up a 118 mph on radar
before with a lighter rider.
Sled#4.My Yamaha Apex GT 06.UNSTUDDED,rider #200.Medium
windshield.Mods-Ulmer clutching-Primary weights,primary
spring,helix,secondary spring.Clutching NOT set as it came from
Allen.GT has reverse remember.Transfer set 1 1/2 lines from min(still adjusting for the best ride).
Line em up time---
Right off the bat I figure I`ll be playing catch up since I have NO STUDS and transfer is not set for whats about to happen.
Off we go and all 3 other sleds are hooking up pretty good and have their skis in the air and are leaving me behind
Sled#2 RTX pulled away slowly from everybody then stayed the same in front of sled #3 RTX mabey 7 lengths.
Sled #1 Fusion slowly fell back,ran good and held its own for a bit,but had no top end today.
Sled#4 My GT.I gave the 3 studded sleds a generous 10-12 length lead at the start as the Ulmerized GT took off with little transfer and alot of track spin.
Before about the 1/2 mile I had caught the studded Fusion sled#1 and said
goodbye
Next up was sled #3 RTX.Between 1/2 and 3/4 mile he said I went by him
while we were at around 90+mph.
So now I was reeling in the sled #2 RTX and was a couple lengths back but we
reached near the end and I had to slow up.
I made up at least 10-12 lengths and put about 5 more on sled #3 RTX.
If I were studded I would no doubt have been way in front of everybody.
Again I didn`t use the clutching set up as it came.The set up I used today is probably not my final trail set up!!!!!
The next day Sled #3 RTX owner picked up a Ulmer kit for his RTX!!!
This is what happened on this day under these conditions with these sleds.
The Ulmer kit -I love it !!!
Line up as follows-
before.
Line em up time---
goodbye
