POWERHAULIC
The numbers are as follows.......
All drivers are white internal/external, and very good quality.
edited corrected info as of 12/07/06
8 tooth #504152552 NOTE THESE DRIVERS ARE 3.0 PITCH, NOT 2.52
9 tooth #504152503 2.52" pitch, this is the one most often used
10 tooth #504152502 2.52" pitch
these drivers are appx. $50 US each
Sorry for any confusion on the 8 t. pitch being 3.0
blown apex
- Jan 29, 2006
- ALTON ILL.
- ristermotorsports.com
apex gt 12 psi supercharger
my drivers are still new looking
full cliped ripsaw/192 studs
2700 miles this year
2300 miles with supercharger
Re: Ski-Doo extrovert driver part #'s
Which ones would I need for a 04 mountain stock?
POWERHAULIC said:The numbers are as follows.......
8 tooth #504152552
9 tooth #504152503
10 tooth #504152502
POWERHAULIC
Stock drivers are 9 tooth.
If you are not changing track height, same amount of teeth.
Depending what you need for bulkhead clearance will determine.
POWERHAULIC said:Stock drivers are 9 tooth.
Thank you!!
RX Mountains came from factroy with 8t drivers in 03/04/05, not 9t.
9t came on short tracks. I have a set in my junk pile if you want to see.
Thanks Red I am getting tired of ratcheting in the deep stuff and if I tighten the track it is too hard on the hyfax so new drivers are in order.
POWERHAULIC
Red, I thought the mountains had an 8t driver. So I went to the parts book, and they listed a 9t driver.
Prob. bad japan/english lang. conversion...lol
If you have bulkhead clearance, it would roll better w/9t drivers. Although you will have to regear accordingly.
thinksnow
Extroverts
I have 8-tooth extroverts on now with a 2" track. What would I need to go with to run a 2.5" track? I really don't want to mess with the gearing and clutching. I am real close on the tuning. My present extroverts are trashed from running the 159" too loose with the turbo.
Lance
P.S.--I already have a drop and roll with the MPI tunnel so clearance really isn't a problem.
Lance
Jack_Shaft
I thought the shaft size of the Ski-doo's was 1/16" larger than that of the Yamahas, no? I was going to recommend these sprockets to a friend of mine with an RX-1 but I wouldn't based on the difference in the drive shaft size.
-JS
-JS
I have Wahl bros 9t 2.52" drivers on my sled. It has variuos levels of boost from 5 to 21lbs, 2300kms with no problems. I used the polaris ones with the 1" shaft, so less chance of slipping on the shaft. Lance I would think you could go with the 2.5 track with 9t 2.52" or 8t 3" drivers.
hot rod rooster
- Jan 9, 2005
- saskatoon, saskatchewan, canada
- www.arrowheadcustoms.com
the rx mountain used a 8 tooth 2.52 pitch driver in them if you go to the 3 inch pitch drivers you ned to use 7 tooth if you use the 2.52 pitch ones you can run 9 tooth with a 2 inch track and not rub.
hot rod rooster
- Jan 9, 2005
i have the 7 tooth 3" drivers and they are showing some wear in the extro teeth. if i did it again i don't think i would use the wahl bros ones unless they have changed thier plastic compound. i am running a 2.25 in track with only about a bit over a 1/4 inch clearance. the 2.5 inch trac was very tight and would rub untill it was tightened up.
Custom Sled Shop
WOW!! GOOD INFO!!!!
I am running a camo 144 1.5 2.52 pitch track on a 04 rx-1
will this driver fit on my shaft? and can I run a 8 tooth insted
of the 9??
thanks for the info!!
of the 9??
