Fat boy spring changing help...........please, I need it
BLUEDOG
St. Louis, MO
Just curious about the best way to dissamble the rear suspension and remove the old shock and replace with the fat boy spring? Any help would be appreciated?
Thanks in advance,
Ron M
This guy here is a great help and the cold dont seem to bother him much. With any luck he could help you out. lol :tg:
I would help you out if I could bud but I have never done it before.
LOL
Bad-boy bad-boy,
what cha gon-na do
what cha gon-na do
when they come for you
just kiddin!
You need to be in the Apex forum and get help from guys like bounty hunter
Take bolts out of limiter strap OR unscrew transfer rod adjuster.
loosen both bolts that hold you shock.
then just put a little pressure with a car jack(or let track down on floor a little) under you track.
you'll feel shock loosen up when you get the right amount of pressure.
unscrew your dial cable.
take out bolts and it comes right out
Spring
You guys are the best...thanks for all the help, especially Sled Dog, man my toes are still numb!!! LOL
Easiest trick to pulling the shock or the entire suspension is to remove the control rod rear mounting bolt, much easier than limiter strap. Only caution is when reassembling, if you increase preload or installed heavier spring the holes in the control rod and rear arm won't line back up unless you get someone to compress the rear sus.
Question,
I havent done this myself on the monoshock.
Does he need a spring compressor to get the spring off the shock and the new one on?
You need the shock compressor when switching the spring on the RTX, Don't know about the other models though.
Fat boy
Thanks for the suggestions but I was able to figure it out on my own this morning, yes a spring compressor is required and an extra set of hands would have been helpful...Now was it worth the hassle???
Dog
