dlange
Guys I'm looking for a set of skis for my attak. I trail ride aggressive, and want to hit some big powder this year. I was thinking of a set of simmons, or c@a razors. What would be the better choice? Bluedog was kind enough to let me try out some simmons on my viper last year and they were sweet. Should I stay with them on the attak?
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Simmons all the way,we ran a set all last year on my rtx so sweet,and now i have a set for my apexer.dlange said:Guys I'm looking for a set of skis for my attak. I trail ride aggressive, and want to hit some big powder this year. I was thinking of a set of simmons, or c@a razors. What would be the better choice? Bluedog was kind enough to let me try out some simmons on my viper last year and they were sweet. Should I stay with them on the attak?
Tork
Hey buddy
Before I forget, how fast is your modified Dodge Diesel in the 1/4 mile?
I like Simmons, but want to try the Pilots
some reading for you
http://www.ty4stroke.com/viewtopic.php? ... =pilot+ski
dlange
hello
Hey tork how are ya? Last year I ran a 12.6 at 110 in the quarter with a big single charger. I have not had a chance to run it with the twins yet this year, but I think I will be around 12.2-12.0 range. Only a couple months to go!
vice108
simmons rock on my Apex
studdog
I've run most, You should consider Slydogs Powderhounds if you want good control with easy steering.
studdog said:I've run most, You should consider Slydogs Powderhounds if you want good control with easy steering.
These were my choice for my Attak...but it was all based on paper. Will report back on actual ride experience sometime this winter.
dirkdiggler
Suspended
I ran the regular Slydog this past winter after using C&A Pro's for 5 years on all my sleds. They the slydogs were very nice and worked well in all conditions.
Lee F
I'm in the same boat as dlang, looking for the best for my Attak GT. I had Simmons on my Warrior, and they were great, but the steering was very hard. By the end of the day I was worn out.
I have been leaning toward slydog trail skis with ski savers and Bergstroms, but I still haven't made up my mind.
I liked Simmonds on my Viper, but too much ski pressure on my Apex. I did a test with Simmonds & Slydogs on same day (same 100 mile loop each) Both had a small amount of darting, but Slydogs turned so much easier. I bought a used Attack at end of season that had stock ski's with dual runners. They did not dart, but I am going with Slydogs with Birkstom triples & ski savers for this coming year. May have a set of used Simmonds for sale after 1st ride (I hope).
Doug
Doug
Tork
SkiDoo Pilot 5.7
Simmons
Slydog
Simmons
Slydog
ecopter
Sorry, don't have an opinion yet. However, I installed a pair of Razors on my Attak and am anxiously awaiting to give 'em a shot. I read a post back in the Spring by BlueByYou2000 and he remarked they were the best ski he's ever run. That was enough for me to buy them.
Jon
Jon
studdog
Tork, I've heard good reports of BRP ski but have also heard they're kind of fragile and don't hold up to rough use. Did you run them last year? Studdog.
bgbytoys
- Jan 25, 2006
- upstate ny
- www.troycitygarage.com
for all the guys complaining of to much ski pressure. adjust the transfer. i went from full ski pressure to just about none when i switched to the simmons.
sometimes you just can't bolt things on, other adjustments need to be made.
yamaouch08
- Jan 17, 2006
- Otisville,Michigan
- www.chapmanssports.com
simmons on my Apex Gt. The best upgrade I could have done. Don't follow the trend of the BRP Pilot skis,I ride with a lot of Doo riders and they do not like them because they are so weak and fragile and thet also dart!
