jp@weknowsnow
- Jul 19, 2006
- colorado mountains
- weknowsnow.com
I understand many Phazer owners might not be interested in this but here is the first of a couple of mods we completed on the Phazer MTN Lite:
Cheetah Factory Racing Rack Install
Installing a CFR Rack on a 2007 Yamaha Phazer Mountain Lite requires a couple of slight modifications to the sled and also to the rack hardware. Below is a series of pictures and brief description of what AKD and I did to get the rack installed. CFR Racks are bomber and I'm really happy with the product, check them out at <a>http://cheetahfactoryracing.com</a>
Disclaimer: This requires you to drill into certain areas on your
brand new sled. Double and triple check everything, you don't need
to follow these directions 100% - They are meant to serve as a guide as
to what we did to get things working. Your install should be pretty close. <a>weknowsnow.com</a>
This method doesn't need an air rivet gun for installation.
Step 1: Read, Understand CFR directions and assemble rack
Step 2: Remove red stock Phazer reflectors from tunnel
Step 3: Remove Phazer rear tunnel box
Step 4: Install snowboard in CFR Rack, place between tail binding or position which ever way works best.
Step 5: Place the metal J hook just behind the first rivet on the tunnel just under the Phazer rear tunnel box. (which you removed earlier)
Step 6: Mark metal J hook upper hole locations with Sharpie.
Step 7: Place CFR U bracket over recently removed reflector area. Mine mounted under the reflector holes almost flush with the tunnel support.
Step 8: Mark locations of lower CFR U bracket.
[PICTURE]
Step 9: Drill Holes for upper metal J hook. Secure with hex key bolts and nylon nuts. Washers on both sides.
Additional Hardware Required:
(3) Hex Key Bolts - #10-24 x 3/4"
(6) Washers - #10
(3) Nylon Nuts - #10-24 LOCK NUT COARSE
Step 10: Drill Holes for lower CFR U bracket. Secure with CFR hardware.
Step 11: Install Phazer rear tunnel box
Step 12: Go snowmoshredding ASAP and checkout <a>CFR!</a>
[PICTURE]
(6) Washers - #10
DELTABOX
Great info thank you. How much is the rack?
jp@weknowsnow
- Jul 19, 2006
- weknowsnow.com
$130 via Thin Air Motorsports (Truckee, CA) -- Google them
CFR is by far the best rack system out. Compared to the rack yamaha offered this is clearly the better choice. And saves 70$ too....
ken_climb
Thats pimp!
swamps
- Sep 12, 2006
jp@weknowsnow said:$130 via Thin Air Motorsports (Truckee, CA) -- Google them
Nice rack man did you happen to find something to hold possibly a extra gas can in the back or something like that for storing stuff on the back of the tunnel?
jp@weknowsnow
- Jul 19, 2006
- weknowsnow.com
CFR (http://cheetahfactoryracing.com) makes some really nice tunnel racks. two sizes. http://cheetahfactoryracing.com/drack.htm
swamps
- Sep 12, 2006
jp@weknowsnow said:CFR (http://cheetahfactoryracing.com) makes some really nice tunnel racks. two sizes. http://cheetahfactoryracing.com/drack.htm
Nice that's exactly what I was thinking about good stuff
Yellowknife
- Jan 25, 2004
- Yellowknife, NT, Canada
- www.youtube.com
That is one super thin tunnel with a big hole in it...I don't know how much weight, especially bouncing weight on the bumps that this tunnel could handle...
2BLUE4U
I'm not a snowboarder but it looks like you're gonna have fum this winter
nice job!
nice job!jp@weknowsnow
- Jul 19, 2006
- weknowsnow.com
swamps said:jp@weknowsnow said:CFR (http://cheetahfactoryracing.com) makes some really nice tunnel racks. two sizes. http://cheetahfactoryracing.com/drack.htm
if you need prices or quotes on any of the CFR products, let me know via email or PM.. i can get this stuff quickly and for a good deal
Climbmax
Sweet............does it also pack some shaped skis?
CM
CM
ken_climb
Yellowknife said:That is one super thin tunnel with a big hole in it...I don't know how much weight, especially bouncing weight on the bumps that this tunnel could handle...
I think there must be something holding the board from tunnels grab handle too...no?
jp@weknowsnow
- Jul 19, 2006
- weknowsnow.com
climbmax- yeah there are a few CFR ski bracket/rack options. let me know if your interested in ordering anything from them
yellowknife: ????? huh?
Yellowknife
- Jan 25, 2004
- www.youtube.com
oh, I was referring to putting a rack with fuel and stuff back there, not the snowboard rack.
redsnake3
we got our new phazer posters in last week and it had a snowboard rack on it from yamaha, i guess they are still gonna make it here in canada.
- 6K
- 23K
