rage man
Dual Electrode Spark Plug
Increase of consistant 2-3 hp in all 4-stroke applications
$32 for Apex/Attak oor RX-1/Warrior
$24 for Vector/Rage/Nytro
from ulmerraging
is that really true 2-3 hp???
from ulmerraging
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Yep, its really true
welterracer
Yes its true.. Suppertuner was the first to give out this bit of info when the Rx-1 came out.. He used them in all motorycle engines for some easy HP..
jimmie d
Many went to them to avoid the fouling problem with the 03 RX1 and than found the benefit of increased performance.
Jim
Jim
NB-NYTRO
could they hurt the engine in any way?
p0wd3rp1l0t
which one would be applicable to my rage?
srx70024
Aren't these a colder plug than the stock Apex plugs ?
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Yep.srx70024 said:Aren't these a colder plug than the stock Apex plugs ?
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
1000 miles of trail riding last winter plus 55 miles of 500' at a time racing this summer and I'm still running the same set of plugs. If they don't foul on us in the grass with the extra fuel added in the low end they won't foul out on the trail. In 3 years I think I've heard of 2 fouled plugs from customers and generally it was because the choke was left on too long.
KnappAttack
- Feb 19, 2004
- Welch MN
They have never fouled for me. They won't do any damage to your engine. If you run the cr10ek on the trail for a while, and stop and put the stock plugs back in you will think you have something wrong with the engine, (slow responce and slugish). Put the cr10 ek back in and like magic the power comes back, it is that noticeable. Mike Knapp#17
SledFreak
- Feb 7, 2005
- Ontario. Canada
So, why do you think Yamaha, just does use this plug right from the factory?KnappAttack said:They have never fouled for me. They won't do any damage to your engine. If you run the cr10ek on the trail for a while, and stop and put the stock plugs back in you will think you have something wrong with the engine, (slow responce and slugish). Put the cr10 ek back in and like magic the power comes back, it is that noticeable. Mike Knapp#17
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
so what is the plug for the 3 cyl engine?
- Apr 17, 2003
- Menno, SD
- Menno, SD
Actually Yamaha is using them this year in the new Phazer model. Gade-thrasher, the plug is the same for the 3 cylinder. For any Apex guys make sure you get the caps for the tips of the plugs as the Apex uses a solid tip plug stock so you'll need the threaded caps.
KnappAttack
- Feb 19, 2004
- Welch MN
We run them in turbo applications at over 30 lbs of boost, deto engines, burn valves and distort bores. Never once had an electrode "fall off". I think they be fine in a trail sled! I don't understand your point. Ever think it was because they are indexed no matter which way they are faced? Leaning out or richining mixtures? No, If anything they would burn the mixture sooner and more complete, i.e. advancing timing slightly, because the spark is more exposed to the chamber. A spark plug does nothing to change the mixture, certain not to efi also. Don't over analayze it. THEY MAKE MORE POWER!!!!!!!!!!!!
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
Mike, not trying to argue, I know lots of people run them with no issues.
Just trying to explain what they are doing. That is fact...that is how spark plugs work. Nothing more.
- 13K
- 11K
