obile
just bought a s/c for my 07 mtn looks as though the belts could be replaced.anyone have the part belt numbers to order from local parts supplier? how much do they cost and where do you s/c guys buy them?
also curious about the special transmission fluid used in the s/c?
TurboJamie
The belts are available from a local gates supplier.
The Oil in the supercharger is supposed to be propriatary to the rotex charger and should only be bought direct from your provider. I swear the stuff smells identical to this stuff we use in a CVT transmission on a machine here at work and looks the same.
obile
ANY BODY HAVE THE BELT PART NUMBERS AND MORE INFO ON THE OIL?
TurboJamie
The belts should have the numbers on them. I can check for you this weekend I will be with my seld.
BlgsRX-1mtn
- Apr 16, 2003
- Billings, MT
- '03 RX-1 Mountain LE
Here's the cheapest place to get the Traxion oil for the SuperCharger. This should last you a while. www.w2wpowertrain.com/c-83-rotrex-maintenance.aspx
Jim
Jim
obile
THANKS JIM added to favorites any info on belts. the numbers on mine are unreadable?
BlgsRX-1mtn
- Apr 16, 2003
- Billings, MT
obile said:THANKS JIM added to favorites any info on belts. the numbers on mine are unreadable?
The best place I could find was by going to http://www.gates.com/industrial/distributors/index.cfm?location_id=3342 and typing in my local zip code. I haven't gone to any of my local distributors yet but when I do; I'll just take my belt along with me. The guys there should be able to match the belt even though the numers are now gone.
I'm not sure it helps but I'm fairly certain that MPI is using a 14 mm wide PowerGrip GT 2 belt and pullies on these applications. Here's the direct link to the belt at Gates http://www.gates.com/brochure.cfm?brochure=921&location_id=743. Just take the belt to your local distributor for a cross reference to get the needed length.
Jim
whitee
Heres the part# 6008mgt20 and here. http://www.frenchgerleman.com/frenchger ... 07-834.pdf is what it should cost! It is way down about the middle of the page
Hope this helps, Jason.
BlgsRX-1mtn
- Apr 16, 2003
- Billings, MT
whitee said:Heres the part# 6008mgt20 and here. http://www.frenchgerleman.com/frenchger ... 07-834.pdf is what it should cost! It is way down about the middle of the page
Thanks, for the info Jason. So did Kord sell his TRX-1? I noticed he had it listed on SW a while back.
Jim
obile
anyone got the part # for the other belt
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
- Apr 17, 2003
- Menno, SD
- Menno, SD
Updating this post with correct information.
Apex/RX-1 Supercharger belts
-Crank to Supercharger jackshaft: 6008mgt20
-Jackshaft to Supercharger: 3848mgt20
Vector Supercharger belt:
6408mgt20
6408mgt20
JayyDee92
- Dec 4, 2022
- Saskatchewan
- 2010 Yamaha Nytro MTX FX SE (SuperCharged)
Any buddy every problems with they’re belt slipping off ?
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
You have to make sure they are aligned and tensioned correctly. Its quite a process to align them.Any buddy every problems with they’re belt slipping off ?
Check out the vid to see my process:
JayyDee92
- Dec 4, 2022
- Saskatchewan
Awesome thanks. I’ll have to give it a try I just took my tensioner pulley off because the old belt jumped off I’m running 25 tooth on top pulley and 29 tooth on crank pulley
