Ya Mahn
Would anyone know what type of oil is used for the supercharger? It feels like a light weight oil?
http://www.rotrex.com/pdfs/Rotrex_C-type_supercharger_installation_instructions-V1.4.pdf
http://www.w2wpowertrain.com/pc-49-83-rotrex-traction-fluid.aspx
TWIN TURBO
- Aug 30, 2005
- Chicago IL.
- www.powerbygns.com
Took a brief look at the specs on the Rotrex traction fluid and it is extreemly light weight oil the closest thing I found was trans fluid but its still doen't meet the specs. $95.00 per quart is a little ridiculus. Hammer this is a good job for you , find something for us will you?
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Found this article pretty interesting. The traction fluid is made here in the usa by a company called Santotrac. It was designed for toroidal continously variable transmissions because they use metal on metal for the transmission of power. This stuff actually turns into a solid under ultra high pressures and can increase grip by 50 to 100%. Pretty cool. The reason a rotrex blower needs it is because it uses a metal on metal speed multiplication roller system. Just an interesting bit of knowledge for anyone contemplating putting regular oil into a rotrex blower.
http://www.chemassociates.com/products/findett/Santotrac_USU_Mini_Baja.pdf
TurboJamie
I wonder if you could dump that stuff into a slipping automatic tranny.
