Phazer Gearing
Srxspec
Ulmer Racing
Tech Advisor
Menno, SD
Website
www.ulmerracing.com
2014 Yamaha SR Viper LTX, 2014 Yamaha SR Viper RTX SE, 2015 Yamaha SR Viper MTX SE 162 (turbo), 2015 Yamaha SR Viper MTX SE 153
LOCATION
Menno, SD
WEBSITE
www.ulmerracing.com
Per testing and seeing specs on the Phazer, Phazer FX, Phazer GT, and Phazer Mtn Lite someone had asked about gearing on these sleds.
Phazer & Phazer FX:
-Gearing: 18-41 (2.28:1)
-MPH: 81 MPH @ 11,100 engine RPM
Phazer GT:
-Gearing : 20-41 (2.05:1)
-MPH: 90 MPH @ 11,100 engine RPM
Phazer Mountain Lite:
-Gearing: 17-41 (2.41:1)
-MPH: 68 MPH @ 11,100 engine RPM
Also remember when calculating MPH that it is based off of clutch RPM and not engine RPM when using a motor with gear reduction from the crank to the pto shaft (clutch). The Phazer has a 30% reduction from the crankshaft to pto shaft. Example: 11,100 engine rpm = 7770 clutch rpm
***All MPH is based on calculations and how fast the sled can go before the clutches shift to the point of locking up and no longer shifting out.***
Add 11% to MPH numbers and you will see speedo indicated speed.
I am in no way, shape, or form saying this is how fast your Phazer will go. I am simply supplying the information that with enough HP how fast your Phazer could go with it's factory gearing.
Dynojet track dyno is accurate MPH reading. Apex, RX-1, Vector, and Phazer all show 11% higher on speedo than actual speed. Port-a-tree timing system with MPH sensor as well shows the same results. Speedo is off about 11%.
Wow, so when Jeff ran that 91.85 MPH at that track was reading like 100 on the speedo? Crazy.
Good info,
-Steve
Sxrspec wrote
Also remember when calculating MPH that it is based off of clutch RPM and not engine RPM when using a motor with gear reduction from the crank to the pto shaft (clutch). The Phazer has a 27% reduction from the crankshaft to pto shaft. Example: 11,100 engine rpm = 8100 clutch rpm
I believe the gear reduction is actually 50/35 or 30%. Example 11,100 engine rpm = 7700 clutch rpm. So you need to reduce your calculated speeds accordingly.
Also the Mnt Phazer has 8 tooth drivers.
With these in mind - Phazer Mt Lite -MPH: 62MPH @ 11,100 engine RPM
yamy07, updated the above post. For some reason I had it stuck in my head that it was a 27% reduction. Oops! You can take 10% away from the above MPH calculations and get the 1:1 clutch ratios (most efficient areas of the clutch to be in).
Great information guys. Thank You. So My Mtn. Lite with 19/41 low altitude gearing could see approx. 70 mph actual, and 77-78 on the speedo? If so that is right where My seat of the pants feeling was when I rode mine last weekend. I guess I can live with that. :-o
:letsnow: :letsnow: :letsnow:
So would it then be a smart or neccessary mod to change the FX to 20 tooth upper with a 140-150 HP turbo kit, including the new Freeride 136"x1,5" track ?
Or maybe even 22 or 23 tooth if possible ? That would give 1.86 or 1.78 ratio and close to the "magic" 100 MPH real world speed mark. Who would like to go faster than 100 with a long track FX anyway ? ;)!
My 98' MachZ with 136"x1,5" track was geared for approx 110 MPH but rarely was driven past 100 MPH. At about the same power but 120 lbs lighter, I can imagine the FX turbo beeing a rocket :Rockon:
This is why the Phazer is lightweight :tg:
Hey Teerex I got to ask, are you at all worried about that little gear when you put the turbo to it? There just doesn't seem like a lot of meat to those gears IMO.
