K-APEX
I know they make a 12v adapter in which you can plug in your shield on the Apex. Has anyone used it? Does it work well?
Has anyone wired their shield to a source under the hood? If so, to which source/wire did you connect into? Any pics or instructions/advice on how you may have did it would be appreciated.
Thanks.
Thanks.
kenbar
On my 2007 Attak, the dealer spliced the positive into the blue/red stripe wire at the handlebar which provides the power for the brake light. The negative is connected to a bolt on the riser. Works well, you can hide the conncetion, plus it is only powered when the engine is started.
I could not find this wire in the diagrams. I discovered it was the brakelight wire while I was resplicing due to a bad connection. The colour coding may be different on the Apex.
pat the rat
- Mar 13, 2006
i wired my rx to that wire last year but had a problem burning fuses all the time,so i went directly to the battery and no more problems.just did my phazer the same way.
T-Bone
pull apart the electical conection for the accessory plug, cut and stip ends of electric shield wires and jam them into the accessory conector and snap it back together. I have always done my electic shields this way and have never had a problem. No fuses are needed as the 12v accessory plug is already fused.
albird1
- Mar 19, 2006
cheap and easy way to fix it
I ordered one from a catalogue.
it cost $6.95 and it has a light to indicate that it is on.
Dealers also sell such a part but it is more money.
I can't remember the name of the catalogue but it is one of the big ones that sends me a catalogue every year.
good luck
Remember: Keep the shiny side up and the flat side down
good luck
Taz107
- Feb 18, 2005
Buy the skidoo visior plug kit, mount it beside the 12v outlet, splice into the wires for the factory outlet, and your done. Looks like a factory installation, even comes with a heated visior decal, and leaves the 12v outlet free for GPS, cell phone, etc....
danq
I adapted an optimate battery charger harness directly to the battery. I soldered in the visor portion and took advantage of the fused part of the optimate.
Advantage: always on, so if I leave the helmet plugged in while we take a trailside break, it should be fog/ice free when we take off.
I had a bunch of trouble with my heated shield last year that was wired to the tail light circuit, but I could never determine if that was a wiring problem or if the shield was the problem. this year I've eliminated both possiblities with a new shield and direct wiring...
If you wife to the tail light, be sure it is the tail light and not the BRAKE light..... (i did that once)
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
direct battery (WITH A FUSE) always on, will defrost while sled is off !!!
Bigger Hammer
Tapped into the 12v plug myself, if I have problems with fuses blowing will just stick a 4A or 5A fuse in, they are the only things on that circuit anyway. Personally, I would not wire it up without a fuse either, just imagine if somthing shorted....
kenbar
The blue/red wire I mentioned earlier is always hot. It is the power for the brake light but obviously the light is off until the circuit is completed by pressing the brake. I can't see any reason why fuses would blow using this setup. This should work.
Any comments? Maybe I am missing something. If so, I can change to another place.
ecopter
I wire off the power wire from the headlight switch. Any circuit used on the handlebars is already fused at the panel box under the cowlings. Never had a problem with tapping into that wire and grounding to the handlebar bolt.
Jon
Jon
RX-1 Liter
- Apr 14, 2003
- Chautauqua County, NY
- 2017 RMK 155"
Much easier to just buy the cigarette style adapter from Yamaha that has the RCA adapter pre attached.
MyOutdoors
- May 4, 2003
- Lempster, NH
- 2020 Sidewinder Ltx Se
danq said:I adapted an optimate battery charger harness directly to the battery. I soldered in the visor portion and took advantage of the fused part of the optimate.
I had the same problem last year, I tried a few different places and the battery with a fuse is your best "no-hassle" bet.
Len Todd
Direct to the Battery with a fuse as close to the battery as possible.
- 9K
