jbsr
has anybody worked out fuel numbers for mpi @5psi sea level. apex
SPEED
Jbsr , Contact Allen At Ulmer Racing I believe he has some base numbers for 5lbs. and most everything else you need for the S/C.They are at the altitude we are here in the east
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Apex fuel numbers for 5 lbs of boost.
Elevation: 1350'
Mode 1: 1
Mode 2: 2.5
Mode 3: 2
Mode 4: 4.5
Mode 5: 1
Mode 6: 8
Elevation: 1350'
Mode 1: 1
Mode 2: 2.5
Mode 3: 2
Mode 4: 4.5
Mode 5: 1
Mode 6: 8
jbsr
Thanks for the fuel info Two more questions.
What is being done to fill the big hole over the intercooler.?
I'm thinking of modifying the air box top.
How about clutching. I.m doing two super chargers. One on afrien who weighs about a hundred pounds less than me. Any difference.
Sea level trail riding
- Apr 17, 2003
- Menno, SD
- Menno, SD
Hole over the intercooler, some guys have used the stock air box lid and cut it and glued it to the hood. The other option is to get BPE hood scoop for $109.
I use the 60 gram adjustable Yamaha weights from http://www.supremetoolinc.com and have a complete kit that includes primary spring, weights, and a helix for $365. A 100 lb difference in riders will definitely require a different weight setting between the two.
