Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
What are you guys doing for the caps that are needed? Also, what do you do to keep them from un-screwing?
zipclean
Just put mine in last nite.I put a drop of red lock tite on the very bottom threads,screwed the caps on and tightened them snugly in a vice with a plier.Should be O.K.Cause it is not a trail side job in snowy, -30c, Saskatchewan,to do.
just find a cheap pair of plugs at the store that have threaded caps..they are universal and will thread right on
stoutner
- Dec 6, 2005
- Seneca Falls, NY
- www.ecsexpress.com
Why are you guys putting these plugs in? Are they supposed to give you better HP or mileage or something?
They will add about 3 hp based on testing done by a couple of different racers on this site.
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
didnt realize they were supposed ot have caps......they didnt come with any so i just snapped my plug caps on it. Did i do this right?
jimmie d
Only the Apex requires caps.
Jim
Jim
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
Thanks guys
stoutner
- Dec 6, 2005
- Seneca Falls, NY
yeah, thanks
radta7
- Dec 8, 2005
- Northern IL
- 2020 Sidewinder LT-X GT
jimmie d said:Only the Apex requires caps.
Jim
Apex and Attak
sledhead317
cr10ek
These are colder plugs than the stock,any one have any problems in the cold weather starting or fouling them.
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
Re: cr10ek
Many guys are running them and I have yet to read of any issuessledhead317 said:These are colder plugs than the stock,any one have any problems in the cold weather starting or fouling them.
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
zipclean said:screwed the caps on and tightened them snugly in a vice with a plier.
geez, please be carefull!! that's a little excessive!
zipclean
Maybe, but I have had them vibrate loose in other sleds and this is not a easy one to get at on the trail at -30c
Yamahammer485
zipclean said:Maybe, but I have had them vibrate loose in other sleds and this is not a easy one to get at on the trail at -30c
Me too, and Iv learned to hate this style of plug tip. On my venture, the plug caps themselves wore down the rim of the tip head, so the caps would no longer clamp and hold the sparkplug. I guess its just because aluminum is a soft and easy to wear away metal, and two strokes shake alot.
Has anyone tried putting a little solder at the bottom where the spark plug tip (when fully tightened) seats down to. Wouldnt that hold it in place?, and it wouldnt require a ton of solder either.
