SC setup and clutching
Maddog
NH
I have a 05 warrior and I am nearing completion on a SC install. Trying to decide on pully combo and also need to start looking into clutching. Right now I have HH in there set up for a filter kit. I know that this will not work to well. I am also considering the pulley setup. Should I stick with the 5psi combo for now or jump right into the 7.5psi. I was considering staying with 5psi, getting it dialed in, then going to 7.5psi. Just seems like I will be doing things twice. Also what rpms should I be looking for?
I have done a search with out any results. Should I consider going back to stock weights and loading them up some?
Maddog, we have setups for the RX-1 and Apex at 5, 7, and 10 lbs. The 5-7 lbs setup is $365.
For that price, what components are included?
Primary Spring, Super Tip weights, Helix.
