How long does it take to prime the system? I have killed the battery trying to get it primed.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Take the top line off and put it into a cup or something you can catch fluid in. Start the sled and let it idle for 30 seconds. Oil should come out by 30 seconds of idle time.
5280ft
For some reason my post didn't show up, but I said the same thing as SRXSpec. Try that.
The SC comes pre-filled and you really should see flow within 15 to 30 seconds of cranking.
I have heard of a few cases where there was no flow, and it turned out the hoses were hooked up incorrectly for system flow. Also, when Al was at MPI he told me that a few SC's we not machined correctly and they wouldn't allow for flow.
I would try the tube to the catch cup and if that doesn't work, then get on the phone with MPI. Also, make sure you use that catch cup...you don't want to loose any of the "mink oil".
Manufactures installation recommendations (Pages-7 & 8)
http://www.rotrex.com/pdfs/Rotrex_C-type_supercharger_installation_instructions-V1.4.pdf
