- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Put on a little over 50 miles today on the 2007 RTX ER all ditch riding in crusty snow. Rode the first 25 miles completely box stock with stock skis, windshield, etc. The front end & rear end seem to work very well together. Front floats set at 65 psi with front end off the ground. The rear end setup exactly as it came from the factory. It did bottom out once or twice, but adding the anti-bottoming stoppers will help eliminate that. After 25 miles I bolted on the Slydog trail skis with 6" carbides & the ski savers. This got rid of all the darting and dropping through the crusty snow that made the sled unpredictable and scary at times with the stock skis! Set the ski alignment in between 1/8" toed-in to "0" or neutral. Then bolted in our Stage 2 clutch kit setup running 10,200 or so (knowing that it will pick up RPM with more miles on it). Also put on a taller windshield. The handwarmers worked great, much better than 2006! The 22/38 gearing definitely makes it quicker down low and doesn't seem to hurt top end too terribly much. We have a 1 mile long road that you can run all out for 1/2-3/4 mile on which had ice underneath with 1-2" of hard crusty snow on top and I saw 128 on the dream meter @ 10,400 RPM with low miles on the sled. This sled is a hoot to ride in the rough stuff, but we had our 2007 Phazer FX as well and that thing is just a blast in the rough ditches! Now I want the Phazer weight with the Apex HP!!
cameljockey
sounds great, what part of SD are you riding?
- Apr 17, 2003
- Menno, SD
- Menno, SD
Riding in the Southeastern part of SD. Menno to be exact. We had probably 6-8" of snow on Friday around 9 PM, but it warmed up and rained all Saturday and we are down to probably 4-5" now and it's fairly hard & crusty. In some of the ditches the water under the snow is pretty deep, but it was cold enough today that most of it was frozen over yet.
hayastusa
That left spindle on the RTX looks a little verticle. Very familiar sight for me, as I've had problems with a-arms twisting on my Attak. Hopefully it just looks that way in the pic.
- Apr 17, 2003
- Menno, SD
- Menno, SD
Nothing bent, twisted, or torn as I looked it over before putting it away. The only thing that happened is the plastic spindle cap popped out somewhere along the lines and is missing.
RTx99
my plastic cap and my buddies both rtx 07 both did wonder whats the problem is there dealer gave me new one!!
Ported Hornet
Srxspec said:Put on a little over 50 miles today on the 2007 RTX ER all ditch riding in crusty snow. Rode the first 25 miles completely box stock with stock skis, windshield, etc. The front end & rear end seem to work very well together. Front floats set at 65 psi with front end off the ground. The rear end setup exactly as it came from the factory. It did bottom out once or twice, but adding the anti-bottoming stoppers will help eliminate that. After 25 miles I bolted on the Slydog trail skis with 6" carbides & the ski savers. This got rid of all the darting and dropping through the crusty snow that made the sled unpredictable and scary at times with the stock skis! Set the ski alignment in between 1/8" toed-in to "0" or neutral. Then bolted in our Stage 2 clutch kit setup running 10,200 or so (knowing that it will pick up RPM with more miles on it). Also put on a taller windshield. The handwarmers worked great, much better than 2006! The 22/38 gearing definitely makes it quicker down low and doesn't seem to hurt top end too terribly much. We have a 1 mile long road that you can run all out for 1/2-3/4 mile on which had ice underneath with 1-2" of hard crusty snow on top and I saw 128 on the dream meter @ 10,400 RPM with low miles on the sled. This sled is a hoot to ride in the rough stuff, but we had our 2007 Phazer FX as well and that thing is just a blast in the rough ditches! Now I want the Phazer weight with the Apex HP!!
That is awesome. I can't wait to ride mine!!! I actually woke up this am unhungover to some snow falling. I am praying that I get to try mine this afternoon! I also look forward to breaking mine in and puttting one of your clutch kits in!
Skydog
YES!!!
man i feel the same way my RTX is unreal fun!
DoktorC
edited for stupidity!!!!!!!!
My post was supposed to be over here....were it actually makes sense...sorry Spec lol.
http://www.ty4stroke.com/viewtopic.php?p=319614#319614
you call that a race
DoktorC
I posted this in the wrong thread!!!! I guess I had too many window open...doh....
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
DoktorC said:Depends on the Apex lol.
http://media.putfile.com/Sledrace15
Mine vs a dead stock Apex ER on the same day (as the above video), same studs mine was faster in the one race where we both hooked up. I've got ECP's and my starting point for clutching...
LOL!! Hardley a race vs your brother there !!!!! He's a PRO RACER!!! What are you?
DoktorC
87gtNOS
- Nov 30, 2005
- Toronto
LOL!! Here's the wheelie king...note the big grin...and the fat gut!!!!
http://media.putfile.com/100-wheelies
- Apr 17, 2003
- Menno, SD
- Menno, SD
107 miles on after today. Still running great. RPM has jumped up 100 or so RPM already. Now as long as we keep cold temps and get more snow it'll be great!
