Woody
- Oct 14, 2003
Has anyone put on the optional Yami heat exchanger / cooler on their Attak? If so, do you have pics you can post? I'm interested in getting one, since it's not too bad of a price, but wanted to see what I'm dealing with prior to purchasing.
thanks
joel
please post pics if you have one
thanks
joel
YammiMoose
Cooler
If you are even thinking about putting one on just do it! I have put them on my Viper, Rx1 and now the Apex. Once I put it on the Viper I never saw the temp light on again even after almost 10 miles without any snow. The Rx1 was another story... Junk from day one.
-Moose
-Moose
SledFreak
- Feb 7, 2005
- Ontario. Canada
I believe the are still on backorder.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
No they are now coming in,we have recieved two in the last two weeks,and already installed it on my 06 apex,piece of cake,just need a cutting device to peel back a little rectangle part of inside trim,to remove old and replace new,other than that it fit great and used the 3 rivets that came with it,and i do not have a pic or a way to get one,but it really is not bad.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
I got mine a few weeks ago...I was lucky,but since then my buds been waiting...all backorder......I hear they should have some in by end of january....
Nice add on...simple install....Here are some pics of my install using a dremel to cut out area to slide it in..
dan
dan
bashley
I'm a little confused at the need for one of these. I've never had my '06 Attak overheat while riding. The only time it got hot was at an idle for 10-15min. I drained out about 40% of the straight glycol that was in it and replaced it with distilled water and now it will idle for 35-40min before getting hot. Stil cool on the trail. Is it snow conditions or outside temp?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
running long lakes at hi speeds with very hardpack mine would overheat....even after going 50/50 and water wetter i had this happen...not as much but still can happen...i felt this was cheap easy insurance to help cool down...the footwell coolers dont get any snow on them from track.....the rear one will help!
dan
dan
yamadoc643
The cooler for the apex while not fit the attak due to the tunnel protectors. You can retro fit a cooler from the warrior but still have to cut hole in tunnel larger and cut 3 to 5 inchs from protectors. I have learned that they have a cooler in the EURO attak model but difficult to get in Canada. Also it has a big COST approx. $600. I have been looking for cooler design to fit the attak 06 but I an getting the run around from Yamaha Canada.
Genesis Extreme
yamadoc643 said:The cooler for the apex while not fit the attak due to the tunnel protectors. You can retro fit a cooler from the warrior but still have to cut hole in tunnel larger and cut 3 to 5 inchs from protectors. I have learned that they have a cooler in the EURO attak model but difficult to get in Canada. Also it has a big COST approx. $600. I have been looking for cooler design to fit the attak 06 but I an getting the run around from Yamaha Canada.
What?? I put the rear heat exchanger on my 2006 Attak last year.......$80.00!! It's the same exchanger as the Warrior.
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
The hole you cut isn't very big...and I think I only cut one side. I simply cut 2 slits in the existing hole and I rolled the metal back, then slid in the tube and unrolled the metal back into place!!
Sno Cat
Genesis Extreme said:yamadoc643 said:The cooler for the apex while not fit the attak due to the tunnel protectors. You can retro fit a cooler from the warrior but still have to cut hole in tunnel larger and cut 3 to 5 inchs from protectors. I have learned that they have a cooler in the EURO attak model but difficult to get in Canada. Also it has a big COST approx. $600. I have been looking for cooler design to fit the attak 06 but I an getting the run around from Yamaha Canada.
Do you have studs on your Attak? If so, did you have to install some protectors for the heat ex? If so, got any pictures of the installation?
AIRWOLF
Guest
HERES THE PART # FOR THE HEAT EXCHANGER
part #
for 121" 8ET-RHECR-KT-OO $41.95
for 136" 8EP-RHECR-KT-OO $85.29
part #
YammiMoose
Sno Cat said:Genesis Extreme said:yamadoc643 said:The cooler for the apex while not fit the attak due to the tunnel protectors. You can retro fit a cooler from the warrior but still have to cut hole in tunnel larger and cut 3 to 5 inchs from protectors. I have learned that they have a cooler in the EURO attak model but difficult to get in Canada. Also it has a big COST approx. $600. I have been looking for cooler design to fit the attak 06 but I an getting the run around from Yamaha Canada.
I am not sure if they will fit the Attack but I have SRX protectors on my Apex. I know they do the job since I had marks on them while on the RX1. I am running 1.325 inch studs.
-Moose
SledFreak
- Feb 7, 2005
- Ontario. Canada
My dealer just called me, mine just came in.
- 146K
- 28K
- 32K
