Installed 2.5 bottle on RTX, system done
NOS-PRO
"The Burnman"
Vendor
Hessel, Michigan
Sidewinder, SR Viper XTX, SR Viper XTX, 2016 Apex XTX and Pro-Line Pro Stock 1000
Here is the start of the Nytro RTX project:
Just took the tool kit out, and there it is! It is a 2 lbs. bottle, and will have to have the siphon tube moved to the side. Wiring will be very easy, but the airbox will be a challenge on this one.
I will let you know more once I figure out the airbox nozzles.
Better yet, who would have thought a 2.5 lb. bottle would fit? It does, and still have an 1/8 inch clearance to the hood.
System is installed, and took less than half the time to do the Apex. Everything mounts on the top of the airbox lid, and there is plenty of room. Don't have to take out the bottom of the airbox to install the fuel plumbing.
Terry it looks great!!!!
Thanks Allen, just need snow now.....
Have you tested the Nytro on the juice yet?
just wanted to know , cause i'm thinking of juiceing mine.
A couple of spurts, but no full runs as I need to get RPM's down to 8,400 at least.
Just got an email mentioning some tricks, so I will play with it this weekend. Working good, just need to fine tune.
sledmontana said:
HI NOS PRO, how did it go? I am looking at a 60 hp for my nytro, is that what you have there? Just want to add a little all around fun and shot for powdery hill climbs, etc.
Advertised 45 horse shot, and working well. About 30 lbs. thru the sled now. The 60 would be great for mountain areas, but just need to run mid-grade or Premium fuel.
The kit installed on Barry's friends sled pictured above, works great! He has put 70 lbs. of nitrous thru the sled to date, with 0 problems. It is a Holtzman system 45 horse. Just takes a good day of tuning to fine tune, but will give you great results right out of the box. Been real busy, so I have not been posting a whole lot on here lately. Just happened to stumble on this one....
