FXNytromtx
Any better shocks out there????
ruffryder
I haven't seen anything, but I am looking. I was hitting some whooped out trails and the only thing bottoming was the front track shock. I have one more click to go on stiffness of the spring, but even then I will have the suspension maxed out. Not sure on the transfer adjustments, figure you can set it up to transfer less and couple quicker, that might make it stiffer, but I think the limits will be quickly reached.
I am not sure if the KMOD solves these problems.
Anyone else have any thoughts for the soft front track shock setup?
Nikolai
If you set the transfer rods to transfer the least amount(nuts cranked upwards to the red mark), it does stiffen the suspension quite a bit and transfer in the deep is still decent.
FXNytromtx
Ordered up a Kmod yesterday so I was wanting to put a better quality shock on but I guess I will just stick to the stocker for now..
ruffryder
any update for this?
curious what you think of the KMOD?
- 6K
