freelheeler
i can't get this thing to run right???? as i'd mentioned in my other post i've been having trouble getting to 10,500 rpms.
so here's were i'm at
airbox mod, 1st ride- kachess special
under tunnel exhaust- kachess special
21/40 gearing
shockwave
05 clutching with all weights taken out
carb heater in the off position
tors disassemblied
elevation 7-9,000'
problem
sleds bogs at full throttle and max's out at 9,200 rpms
slight burble on the trail when i let off the throttle
pulls pretty hard 0-3/4 throttle
when boon docking and need to get on the throttle the bogs hit and i'm stuck... sweet
i've been focused on the clutching however i'm thinking something is wrong in the carbs?? i'm thinking the pipe has leaned things out and i need to bump up the jetting. it's been suggested the needle be set one below the top.
21/40 gearing
shockwave
tors disassemblied
elevation 7-9,000'
problem
