BV1
I assume a few others have noticed that its wearing in rather softly.
Has Yamaha helped any of you on this issue? Mine is starting to bottom more often, can I approach Yamaha with this issue?
Is there a general fix to strenthen it slightly? Or stiffen the suspension slightly, if its already on the hardest setting (spring).
Thanks,
-Steve
Thanks,
-Steve
80h4thephaze
I put on the anti bottoming kit on my sled.
https://www.yamahagenuineparts.com/Snow ... del=Phazer
phaze5
thats why im getting shocks stock isnt capable of the inevitable botomming out . the sled just begs me to crack the throttle . and eventually shes going to give
Shocks has done the trick for me.I may even be interested in buying a set of torsion springs that are wore out from one of you guys.Hoping it will lower my sled a bit more than mine on soft setting.Anyone know how to identify the ratings of the springs?Measure dia?
simonzsayz
solft from the day I bought it. 150 lbs, highest setting. drops 6 inches without me or ice on the machine or in the tunnel. Ordered overload adjuster blocks 4 weeks ago, backordered till wednesday.from lasts weeks backorder. thinking about putting a pipe over the torsionspring, between the spring and the adj. block? Dealer says buy the $600 Racer Kit?! cuz I'm so big? jump so rad? I'm 40 drive hard and think the springs are cheep Jap, soft metal. Still love the sled!!! glad I don't jump alot and don't weigh alot.
phaze5
my pricr for the gytr shocks is gonna be around 1200 bucks if i add a grand i could just get a beater why do they have to charge so much for shocks.how much profit do they need to make,
- 6K
