SnoWarrior
- Jan 13, 2005
- Long Island, NY
- 2024 Sidewinder L-TX LE
Just a heads up. I have put over 500 miles on the skid and really like it. Started riding bad, bucking like crazy, so checked and one of the bolts on the front arm where the limiter strap is had sheered off.
After pulling it apart I found the bolt broke off inside the shaft about 1/8". (about 1 inch of threaded bolt)
I had to use an air gun to get the other side off, so I could match up the bolt. After inspection, the bolt came loose and broke off. The side that was still together had loctite on the bolt. The one that backed out had nothing on it. The threads that were still in the shaft were clean.
Picked up a new bolt and fender washer and put it back together with loctite. No damage done that I could see. The shaft on that side had dropped down a little.
Checked the rest of the bolts on the skid and everything else was good.
Grimm
Are you talking about the bolt that mounts the suspension to the tunnel?
SnoWarrior
- Jan 13, 2005
- Long Island, NY
No the one in the picture. It holds one side of the shaft for the front swing arm. There is a bolt on each side that holds that bottom shaft.
Thanks for the heads up-- I'll have to check mine over
Grimm
Me too, thanks.
Grimm
Well, wouldn't you know it, mine is gone too! The bolt didn't break off and the bushing is missing as well!
Off to the hardware store I go.
Grimm
Fixed it up and ready to ride again. :exc:
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
Grimm, any pictures?
Grimm
No pictures, but it's exactly the same bolt as SnoWarrior's.
192 Woodys
Grimm, what do you figure, it just backed itself out? Was it the same side as SnoWarrior's?
Grimm
I figured it just backed out as well.
Identical position as SnoWarrior's, same side.
sxviper32
should maybe tell a.d. boivin so that could work it out with using a reverse threaded nut/bolt combo so that it won't work out. looks like the way it moves may have to deal with loosening the bolt.
pro116
This has happened to guys on the two stroke side also.
SnoWarrior
- Jan 13, 2005
- Long Island, NY
Grimm, did the bolt that stayed in have loctite on it?
MIne did, and the one that backed out and snapped did not. Maybe I will send out an email to Jeff tomorrow.
Grimm
Couldn't tell if it had loctite on it. It was too dark to see inside the hole.
I'll definitely be giving AD Boivin a call on Monday to get the "proper" spacer sent my way as I just used a stack of washers in it's place.
