RX-1 Carburetor Part Number
bucknaked
Hey guys I have a big problem, I need a part asap for my RX-1 but the online fiche and the ones at the dealer don't show a part number for it. If any of you know the part number for the T's that go from the fuel line to the carb's I would be much appreciated.
THanks in advance.
Ok, so does anyone have a link to microfiche for the Mikuni BSR 37 carbs? I believe that is what is on the RX-1, correct me if I am wrong.
I can't find anything.
For the '03 RX-1mtn they are item number 56. The description is; PIPE. Part number; 5DM-14396-10-00 (same as the number in SnoWarrior's link) @ 2 ea units with a cost of $2.84.
Edit;In '04/'05 model years it is item 57 like SnoWarrior states but regardless of the item number; the part number is the same for all three model years.
Jim
You guys are awesome, I was thrown off by them calling it a pipe. I will call the dealers tomorrow. Once again thanks.
Hey guys it turns out that those are the wrong T's. I have posted a pic, the one i need is on the left, the one on the right is the one I just purchased. If anyone has any idea's or even a used one I am getting desperate.
Thanks in advance.
Do the two black pieces come out of your old ones and slide into the new ones? Those are the only two tees that I can see being the correct part numbers.
Jim
Ok guys in case any one else needs this part here is how I ended up getting it, this is an email from my brother who found it. This is of course after over night shipping the wrong part and a Yamaha dealer telling me that they don't make it any more.
Hey, here is your part, it seems to be the right color and everything.
I looked up "yamaha carb 1000" on ebay, and a set of carbs came up from a 1988 fzr 1000, looking at the pictures, you can see the tee in the center bottom of the carbs (look for the color).
http://cgi.ebay.com/ebaymotors/88-YAMAH ... enameZWDVW
Then after researching this bike, I found that they seem to have all of the same parts, the fiche I sent you (below) is from a 1994 fzr 1000.
Go to carburetor and look at 52, 45, and 45. The other part with them
(46) is a filter.
http://www.ronniesmailorder.com/fiche_s ... 4&fveh=591
That is the closest thing I have found in all of the research I have done.
(46) is a filter.
Nice find by your brother.
Jim
Yeah he takes pretty good care of me, thanks for everyone's help on this. Hopefully one day this will help someone else
