rx1wizard
What is the easiest way? I have a 2004 warrior and was just wondering what the norm. It looks like the hyfax wont fit through the track openings.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
cut one track window on each side slightly to fit hyfax through
SledderSteve
- Apr 23, 2003
- Orange County California
- Rental
Actually you don't need to cut the track, you can simply twist the hyfax and it will come through the window.
While I hesitate to link to a non-advertiser, I've found this E-Z slider tool to be such a great help in hyfax removal that it's worth it. http://www.spankysparts.com/product572.html
This is truly one of those products where the infomercial type statement "It really, really works!" is quite true. Get one, borrow one, you won't be sorry.
evilchuckster
When you get the hyfax close to the track window you can grab it with a pair of long nose vicegrips and twist and pull it through the window then keep pulling. Once you shove the new one on I use a short cut piece of the old hyfax to bang the new one in place through the window works for me hope it helps you
kcusscam
Good god, I couldn't not image trying to get those on and off with the skid still in the slead, I just did mine and it took a good pair of vice grips and a large hammer to get the off. I needed a block of wood and the same hammer, also used spray on silicon to lub them up before I put them on.
Convert
- Apr 14, 2003
- Lakeville & Nevis, MinNoSnowta
I'm gonna get me one of those easy off slide tools that Sledder Steve mentioned I do four sets of slides every year between different sleds sounds like it will be well worth the money.
Tork
I have had the EZ Slider tool for 4 years and it is great.
This thread is on page 2 of the faq section, lots of helpful handy tips.
http://www.ty4stroke.com/viewtopic.php?t=24790
SledHedz
- Jul 21, 2007
- Northern Michigan
- www.sled-hedz.com
I take the suspension out to do it. This is a good time to inspect wheel bearings, bushings, grease everything, inspect the shocks and springs and check all welds..
I usually find, by the time it takes to remove the hyfax thru the track windows, I can have the suspension out, service everything mentioned above and back in...
Just my humble opinion..
vx700xtc
A phillips screw driver, large DULL cole chisel,BMFH, and 15 minutes, I can change both hyfax in the motel parking lot at 10 pm near 0 F.(been there, done that).
eman
Speaking of hyfax, has anyone noticed any issues with hyfax heating, I changed to a new set on my RX-1 and on my Viper and have had issues with both of them heating up with the new hyfax. Much more than before, I used the factory yamaha slides. We have had heating issues on a packed groomed trail.
Eman
Eman
kcusscam
eman said:Speaking of hyfax, has anyone noticed any issues with hyfax heating, I changed to a new set on my RX-1 and on my Viper and have had issues with both of them heating up with the new hyfax. Much more than before, I used the factory yamaha slides. We have had heating issues on a packed groomed trail.
Eman
Wouldn't hyfax heating be caused by to much track tension or insufficient lubrication?
vx700xtc
If the trail was groomed late at night and froze solid, and you are among the first few sleds in the morning before other sleds have stired it up a bit you will have to go slow or you can burn a set of hyfax off in about 30 miles.
Had some trouble with the 98 xtc, much more with the RX1. Have had very little if any trouble with the Attak.
I still run the RX1 and lead and have had trouble, the guys with the Attaks can smell my hyfax burning and they have no issue at all.
If I can hook a ski in some loose snow I will, if I find any snow I am OK, but when there is no loose snow I really have to watch it.
pat the rat
- Mar 13, 2006
i have a warrior and here's how i do it,cut one opening so the slides go thru,then remove the screw,go at back,insert flat screw driver between rail and slide,pry off about 3-4'',rotate track until slide goes thru hole,start sled,put in reverse and the slide will drop in 2 seconds,if no reverse you can still manually do it,a little stiffer but much easier than a chisel,lubricate new slide and install,dont pass the hole in the front,good luck,30 min job for merx1wizard said:What is the easiest way? I have a 2004 warrior and was just wondering what the norm. It looks like the hyfax wont fit through the track openings.
Indy
Eman
check your boogie wheels. Use a caliper or just a ruler will work. If they are worn much at all, you will burn up your hyfaxs faster. Many riders only check the bearings or look for chunks of wheels missing. You may also consider and extra set of wheels, this helped me tremendously and are a quick and easy install. Last season I had to change all wheels on both sleds at least once. Last season was hell on the sleds.
SLEDSTART
I'm running the 5.35 wheels (polaris) and that REALLY helped on hyfax wear. Replaced all 4 outers and the 2 inners. Still have to watch it on ANY sled on hard pack ice...but all in all I now get thousands out of them instead of hundreds!
