I just wanted to let everyone know I used these plugs and my sled and it started about 150% better then it did with the stock plugs. It also ran much cleaner. It improved the idle as well.
Silver
I used them last winter with the same results as Jt.I highly recommend them.
YAMAHOWIE
Do any of you know the iridium number off hand ?? -- Thanks !
SnowBandit
- Jan 31, 2004
- NH
- www.slednewengland.com
- 2009 Nytro xtx
Where did you get them...
the part number is cr9eix this is a ngk plug. I got mine fron hauck. I think you can order tehm from any NGK dealer.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Murrays auto sells them for about $5.50 each. That's where I bought mine last year.
Silver
NAPA
BigDog05
There is an old post back on 3/17/04 titled Bosch 4 + Platinum plug. DYNAREX states that FREDDIE tested the CR10EK plugs and the NGK CR9eix plugs. Results were that the CR10EK made the most horsepower and CR9eix actually lost horsepower.?????
DYNAREX
you are correct -thats why you da big dog
dynarex
dynarex
