RedlineViper
Does anyone know of a company that makes an insert for the floorboards on the Apex chassis?
xcsp
I'm not sure of any mass-produced inserts but I made a template and bought some "Gravel Guard" trailer fender protective vinyl w/adhesive backing and cut it out and put it on-looks great and has held up well, at least I think it still has held up.
I had 2k miles on the sled when I sold it and it looked great, no peeling or lifting. Originally thought of polishing the runningboards, but that creates more upkeep than necessary. This stuff looks good, and cleans up well.
I had seen a posting awhile back from "Cubby" who had some type of insert, but haven't heard anything more on price and availability.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
SharkAttak
what do you use to make them stick without pulling up?
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
They r self adhesive. Ive had those on my SXR since new and now has 15,00km. Still there after spilling oil on them.
BallsCasten
I've been thinking of using some bedliner paint. You could get any color you wanted.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
SharkAttak said:what do you use to make them stick without pulling up?
i think the key to making them stick really good,is cleaning the footwell thoroughly,getting all wax off....i usually use alcohol.
then try to install them in heated shop...i also use a blow dryer to heat up the metal...
they are really sticky,and mine have never even budged....only time these come off,is if they were applied without cleaning properly...mine still look new.
I couldnt stand how cheap the paint was and started to wear with 50 miles on sled...i had to have something to keep her looking mint.
dan
apltx08
ROCKERDAN said:I bought 05 warrior PADS from yamaha,and just had to cutout the circles into diamonds,but they match perfectly....mine still look new after 4000+miles.
Dan
I did the same thing and it looks and works GREAT!
SharkAttak
ROCKERDAN said:SharkAttak said:what do you use to make them stick without pulling up?
dan
good idea
apltx08
Just start her up and let it warm up the rads under the floor boards will warm everything up and use ISOPROPOLYN to get wax or other foreign products off and they'll STICK real good!
