SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
I also posted on general discussion as I'd like opinions on this fix...I don't plan on trying to break it..so it's all theory til the fat lady sings..lol.
Thanks to Rich Defillipo (Amsterdam, NY) for welding the bulkhead...he's available for anyone needing this service, or any tig/mig welding..good guy. Rides an F cat, though...lol.
The idea here is to pre stress the bushing shaft/a arm bolt and hold it tight to the inside of the cast hole/nylon bushing. Any stress will pull on the bolt head/threaded rod/center casting/ and the whole other side before getting far enough to break off the cast aluminum tab with the bolt hole. The forces here are almost just the opposite of the 'pull' away when catching something with the inside of the ski. It felt strong trying to 'break' the a arm by pulling on it after finishing.
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
Lastly tack weld the upper support brackets to the new lower support..easily cut off or remove both bolts to get out if needed. Again, not the prettiest welds (by me..I didn't have the brackets made up in time for Rich to weld), but they generally stick together
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
This should work on Vector's and Apex's, too..my Apex looks similar..maybe bigger bolts..so just drill a bigger hole in the bracket.
crazyyamaha
Thats a great idea I can't imagine that breaking . God job
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
Thanks. I wanted to use the stock parts. The nuts had at least a 1/4 inch of threads showing, so I used 1/8" plate steel. Other than time, the whole cost for threaded rod, nuts and steel is probably under 5 bucks.
bjowett
Very creative... I like it!
